Like Tree485Likes
Yokomo YZ-2
    Hide Wikipost
Old 11-11-2021, 01:35 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-2
Last edit by: lexusbest
Welcome to the YZ2 Wiki!
Features for the lastest specification YZ-2DTM3.1
  • Long specification for dirt Main chassis Inheriting the chassis cut of dirt specification, it is longer with the same wheelbase as CAL3.
  • Aluminum front suspension mount.
  • Z2-DTM2B F2 body.
  • JConcepts ASTRO High Clearance 7inch Wing.
Features for the lastest specification YZ-2CAL3.1
  • Long specification main chassis for carpets. Long wheelbase that enables even higher speeds.
  • Steel front suspension mount.
  • Z2-DTMBL S2 Lightweight body.
  • Z2-CAL2W LMR Wing.
Common features for the lastest specification YZ-2DTM3.1 / YZ-2CAL3.1
  • The conventional position and the position of the suspension arm pin 1 mm higher can be selected on the front and back of the front suspension mount.
  • Bulkhead integrated side plate with increased rigidity.
  • The kingpin position has been changed with the new steering hub carrier, the axle position has been lengthened by 1 mm, and a steering stopper has also been added.
  • Battery holder that is easy to adjust according to the height of the battery.
  • Separate the rear mount base and upper arm holder to increase the flex around the rear and improve traction.
  • Z2-018-5 5-hole shock mounting specification Rear shock tower.
  • S4-S1S 3.0mm shaft specification front shock.
  • S4-S1M 3.0mm shaft specification rear short shock.
  • S4-008R5B L5 / LD Rear suspension arm (Φ3.5 pin).
  • Z2-01069 Rear universal shaft (69mm bone).
Setup Sheets can be found here
DT CA DTM parts comparison
YZ2T Tranny Conversion List
YOKZ2-300RFT
YOKZ2-302CT
YOKZ2-302T
YOKZ2-304T
YOKZ2-503I
YOKZ2-0023
CAL3 manual
DTM3 manual
Print Wikipost
Old 03-17-2018, 07:31 PM
  #3961
LKracer's Avatar
Trader Rating: 175 (100%+)
Originally Posted by MarkA
Yes, once the grip reaches a point if being "high", everyone at one of the tracks I race that qualifies as such, regardless of skill level, has found themselves faster with the "old" rear end.
Hi could u give me a breif rundown of which CA rear ends parts to swap in for a DTM when the grip is high as you said?
Do you guys just use the older non-offset CA 0deg hubs, CA rear camber plate then remove DTM bulkhead/shocktower brace and gtg? The CA gearbox has a tab and 2 screws to secure to the camber link plate, do you run with no gearbox rear bracing when you remove the dtm brace for high grip?
LKracer is offline
Old 03-17-2018, 08:30 PM
  #3962
Originally Posted by mes
The one thing that comes to my mind are the aluminium bulkhead mounts, but there may be more.
Edit: F2 body, Ti coated shock shafts, aluminium servo mounts, graphite arms, front wing
I wonder if the world car didn't have more carbon/graphite parts like castor and front hubs.
Got the aluminium chassis baces too (top plate mounts), an expensive option.
What I liked about the original YZ2 (and the CA to some extend) was the fully equiped car out of the box for astro/carpet and I seem to find that in the CA2 plus lots of little improvements here and there.
Like it !
mojo tom is offline
Old 03-19-2018, 07:22 PM
  #3963
steam's Avatar
Hi I'm trying to update a YZ2 I have never ran.
question?
Can you not run the steering lock to lock?
The tie rod hits the spring before you can lock it. or do I have something built wrong.
steam is offline
Old 03-19-2018, 09:11 PM
  #3964
Originally Posted by jonski
Any of you guys using Protek servos in your YZ-2? I have a 20% off Protek coupon and have really been interested in trying one of the shorty servos. Any feedback to which Protek shorty servo you are running in your YZ-2 would be appreciated.
Im using the 160t..great servo
Highly suggested
405RC is offline
Old 03-19-2018, 09:18 PM
  #3965
MarkA's Avatar
Trader Rating: 21 (100%+)
We use the gearbox that came with the ca and screw it to the camber mount as all did prior to the dtm. These rear hubs are tangibly faster than anything else when grip gets really high: https://www.amainhobbies.com/yokomo-...-415rs/p509096
MarkA is offline
Old 03-19-2018, 09:20 PM
  #3966
MarkA's Avatar
question?
Something is wrong. Steering blocks should be able to go lock to lock w/o rubbing on anything.
MarkA is offline
Old 03-20-2018, 12:55 PM
  #3967
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
haven't see his issue on rubbing spring, however, I have seen an issue where the steering can bind depending on the servo horn and servo used.
Basically the ball end that articulates from the servo horn can hit the upper brace in the place where it is already recessed to allow free movement. say this when I went with the Ruddog servo horn on the 20mm setting with a protek 160T servo. I had to dremel it ever so slightly.
New DTM2 announced:
Yokomo YZ-2 DTM2 2WD buggy kit -NeoBuggy.net ? Offroad RC Car News
Price is way up there, $415 on amain, hopefully that is just initially what they are just throwing up out there.
Cain is offline
Old 03-20-2018, 01:18 PM
  #3968
AZJP's Avatar
New DTM2 announced:
Haven’t even seen it on Amain. Got a link?
AZJP is offline
Old 03-20-2018, 01:21 PM
  #3969
Tech Legend
Cain's Avatar
https://www.amainhobbies.com/yokomo-...z2dtm2/p754644
talked them and it sounds like the price will be the price.
Need to really read the breakdown on this but initially not sure I am seeing $415 of car there.
Cain is offline
Old 03-20-2018, 01:29 PM
  #3970
AZJP's Avatar
Yeah not a 2wd, even with Yokomo quality. Funny thing, yz-4 sf’s were $489 a week ago, now $529. Also, if you search Yokomo the new dtm doesn’t show up.
AZJP is offline
Old 03-20-2018, 01:41 PM
  #3971
MarkA's Avatar
Yokomo's new slogan, "Working to make Xray look affordable"
The CA2 is currently at $415 as well and even as someone who has ran Yokomo buggies since the first plastic chassis B-max2's were available stateside, I would struggle to make the case to anyone looking for a carpet/turf car to buy it at that...
Cain, jpcopeland1 and stanleyw808 like this.
MarkA is offline
Old 03-20-2018, 01:43 PM
  #3972
Trader Rating: 92 (100%+)
Its the exchange rate as the US dollar last been fallen off. If you want a shock go to Mibo and see what a $30 part costs now in US money about $46.
Cain likes this.
sksdean is offline
Old 03-20-2018, 02:02 PM
  #3973
Trader Rating: 8 (90%+)
It says the DTM to comes with the new S3 rear arms?
I wonder if it's S4 arms in the standard length
catfat is offline
Old 03-20-2018, 02:06 PM
  #3974
Tech Legend
Cain's Avatar
lol, well for now you still get 2 parts for the price of one xray one like a-arms
yeah that's a tough sell there. So if we figure about an 8% increase based on the amount the YZ4 went up, looks like the vehicle would have cost about $382 or so if you take that percentage off the current price.
still up there..
Cain is offline
Old 03-20-2018, 02:14 PM
  #3975
I too, am a little surprised/disappointed in the steep price of the new cars.
BK24 is offline
