Mugen MBX7R Eco thread! >
Like Tree29Likes
Old 04-09-2015, 02:46 PM
  #541
egobrkr's Avatar
Trader Rating: 29 (100%+)
Originally Posted by jjahn
I just got my kit today. I opened it up to start the build and they sent a couple of different packs of screws stapled to a paper stating they were replacements. Anybody know what step these are used on? Or is it that there are enough of these that it replaces all screws of this type?
If I remember correctly those screws are for the front and rear diff case to for mounting to the chassis.
egobrkr is offline
Old 04-09-2015, 03:42 PM
  #542
aaron2u's Avatar
Trader Rating: 75 (100%+)
Originally Posted by JR V
Argh mine was supposed to be delivered today, but still no UPS man..... I am going crazy stating out the window waiting for the brown truck..
Lol, ordered mine from Tower too... paid extra for the shipping! got it sooo fast, I had to duck! Now just have to find time to paint the body and break'r in!
Cheers and happy building!
aaron2u is offline
Old 04-09-2015, 09:37 PM
  #543
mebolson's Avatar
Trader Rating: 41 (100%+)
I got a few in today Gonna have to keep one for myself. It's good to be back with Mugen.
E
mebolson is offline
Old 04-10-2015, 05:59 AM
  #544
Originally Posted by Waflet
Hideeho
I'm not sure I 100% understand your question.
Do you mean there is no way to get any rebound in the shock at all? If so, it's only you.
Do you mean there is no way to get the exact same amount of rebound on all 4 shocks & have it stay exactly that way for a full 5 minute qualifier? That is not just you. That is the problem with building shocks & setups depending on rebound in the shock its self & why I NEVER build rebound into my shocks or setups.
I meant the first one.
Well, I don't think it takes rocket science to fill with oil an ammo, let the air flow out by slowly pushing up and down the piston and then, with the piston in lower position ( max extension ), close the ammo firmly.
Well, none of my 4 new MBX7r ammo has more then few mm of rebound.
Which is the trick here to have a full rebound ( without springs mounted of course )
thx
Emmeth is offline
Old 04-10-2015, 09:05 AM
  #545
Ducky162's Avatar
Hey guys,
If this has been asked before I apologize. I'm converting my MBX7 Eco to a MBX7r ECO and have a set of aluminum hubs I never installed on my 7.
Now I know they made new hubs for the universal drive shafts since they take a 8x16x5. But old ones seem to be able to take either the large or small bearing on the inside of the hub and i did everything but bolt it on the car to see if it'll work.
So can I use my original aluminum rear hubs then?
Just don't want a $80 paper weight set.
Big thanks
Ducky
Ducky162 is offline
Old 04-10-2015, 11:55 PM
  #546
The screws are to attach the front and rear assemblies along with the motor mount to the chassis. Was something wrong quality wise with the original screws? Should I just throw those out?
jjahn is offline
Old 04-11-2015, 06:24 AM
  #547
JR V's Avatar
I am in same position. Lost as to why they give the same screws in the little bags as what came in the kit. Dont know the reason why they need to be replaced.
JR V is offline
Old 04-11-2015, 09:49 AM
  #548
Tarimon's Avatar
thx
Never close your damper with the piston in lowest position...! If you want a minimum of rebound, close it at highest possible position, if you want some rebound you will go lower, but never at maximum extension!
Tarimon is offline
Old 04-11-2015, 01:11 PM
  #549
Is out normal for the steering to somewhat bind and have limited range at full droop? I have mine built to factory setup. I noticed the steering isn't very free, I'm just pushing the linkages with my hand. If I try to go full lock right or left it gets considerably harder and actually pulls up on the arm. If I compress the suspension it becomes free and easily moves.
jjahn is offline
Old 04-11-2015, 02:22 PM
  #550
Gpeters66's Avatar
Mine doesn't have that problem at 103 droop.
Gpeters66 is offline
Old 04-11-2015, 07:14 PM
  #551
TLR_TeknoRC's Avatar
Is the proline phantom body for mbx7r nitro will fit to mbx7r eco? or is there a specific proline phantom body for mbx7r eco?
i cant find the answer on the thread if someone already ask this
TLR_TeknoRC is offline
Old 04-11-2015, 08:17 PM
  #552
Vantard's Avatar
I'm building mine right now and noticed this before I mounted to the chassis or had shocks on. I'm pretty sure it's the front driveshafts. It frees up when they are turned a 1/4 turn for me. Otherwise it lifts the arm trying to turn the universal
Vantard is offline
Old 04-11-2015, 08:38 PM
  #553
Waflet's Avatar
Trader Rating: 35 (100%+)
Hideeho
Fit over the chassis, yes.
Fit over the motor & a full size 4s lipo, no.
Waflet is offline
Old 04-11-2015, 10:03 PM
  #554
Hideeho
Fit over the chassis, yes.e
cant understand what you trying to say in here, is it the simple answer is no? it wont fit?
Old 04-12-2015, 12:08 AM
  #555
R1Joel's Avatar
It won't fit properly. I run mine still but the left side sticks up slightly from the battery.
R1Joel is offline
