Removing Tires off Pre-mounts
#16
Have any of you done this with premounts? I heard those were near impossible to get off.
Agreed. I'd cut into the tire if I really wanted the foam. I don't want to get pots just for tires as I wouldn't eat anything out of pot that's boiled tires.
Not having done this I would not be the one to explain to my wife that I baked tires in the oven and that is why the house smells... not to mention the added flavor to how many meals.
I would either try to boil them or fume them with acetone, but in reality you are only likely trying to put banged up wheels in new tires. In time they can crack around the edges, get a wobble in them, or stretch out the area around the hex making it weaker.
For me, new tires = new wheels, might try to save good foams though.
#19
After spending year in engineering school and having worked for numerous engineering company ranging from chemical to commercial construction, I can tell you right now that if you value your house, dont bake your tires in your stove. INCREDIBLY stupid.
Second, boiling weakens the bond but you can kiss that pot goodbye. If you want to boil, buy a crappy walmart pot for $5 and just throw it away afterwards.
The best way to get the tires and rims apart without causing any damage is to soak in acetone overnight. Acetone is what they use in hospitals to remove super glue from people. Wanna know how I know? Just soak your stuff in acetone over night. It works great.
#20
#21
Thanks for the reply's. My wife loves cooking and cooks all the time so I think the bake option is off the list. Will give the acetone a try. I have 3 sets of new front and rear pre-mounts sitting here and wanting to run a different offset wheel and different color which is why I am asking.
#23
And don't soak the tires/wheels IN the Acetone. It's the fumes that dissolve the glue. I use a couple of old wheels and set the wheels/tires I'm trying to de-bond on those. Keeps them out of the Acetone so that you don't need to use any hand protection to handle them, and doesn't soak the foam.
#25
Use a cheap toaster oven. 30 minutes at 325 degrees.
#26
Acetone in a bucket with a lid works great. Leave your wheels in for an afternoon and it takes all the glue off. Won't ruin the tires or rims either unless they are painted. Foam usually dries out with no problem. Have to use the lid because acetone evaporates not to mention the fumes.
#27
Some premounts are glued better than others. The Blockades took easily 3 times as long to get off as the Tazers. Just happens some time.
If that's your experience, you were doing something wrong. I've removed many a tire off a rim and never destroyed a closed cell foam.
