Xray XB8E thread
#1130
I am looking to buy a xb8e'16 for bashing around. I already own a xb2 for racing and I really like that car. It is one of the most durable I own so far.
I know that the xb8e isn't made for bashing, but I prefer a quality and durable car for bashing. I can get easy access to spare parts.
I would run it with a Hobbywing ezrun max8 esc with 2200kv motor.
What do you guys think? The reason I do not bash with my xb2, is because this car is to small.
#1131
i got my car up to 2017 specs.. and its a much better car than before.. i highly suggest it.. the front trailing hubs, front steering plates, rear end parts.. i would do all those.. then the diffs.. i noticed least improvement from the diffs.. however.. the ballooning front was eliminated..
#1133
2015 Xb8e - Input please
Hay guys,
I have the chance to get a new 2015 Xb8E in the box. Is this still a good buggy?? Just sold a losi 8ight E 4.0 before I had a chance to run it. Was looking for a good used 2016 Xb8E but cant find one. Your guys thoughts???
#1134
2015 vs 2016
I Hear that 2015 was better for indoors than outdoors.Xray is a good buggy no matter what but with a older buggy see if you can find some set-ups for it. I know the newer rear shocks will help on landing.
#1137
If you're an experienced driver and you found a good deal, that is still an excellent platform. However most xray drivers I met tend to switch to the newest model, hence support for older models decays quickly as well as the chit chat on the forums. No problem instead for parts support.
#1138
Hi guys! I am thinking about weight balance of my XB8 2016 and less rear traction and I have one question for you... What is your orientation of plastic battery plate? First battery and then ESC or opposite direction?
In my case, I have first battery-ESC.. My car suffers less rear traction and hits to chassis in the front. I know, I can do a lot of chassis settings changes...BUT..
Our best driver on the track has opposite setup - first ESC and then battery as well as Ty Tessman.. So maybe I could lighten the front and achieve better rear traction only with one change!
Does it make a sense? What do you prefer?
#1139
Has anyone heard anything at all about when XRAY will release the 2017 xb8e?
