Tire Tech Talk - Compounds, Wheels, Inserts, Sauce!
#32
Running clay typos on both my sc10 and b5m. Been using wd40 with great results. Tried liquid wrench on my sc10 and no good. Wondering if it would work better on my buggy tires. Since they are the same as my sc10, I am assuming they would behave the same. Saw a video from Jason Snyder saying liquid wrench really worked well with his dirt webs. He was at a different track so I am thinking results may be track dependent or both track and tire dependent. Has anyone tried liquid wrench on clay typos with good results?
#33
#34
Where do you race? What's the track surface like?
Tire selection is one of the harder aspects of tuning in my opinion. You have several factors to consider. Tire tread style, compound, inserts, wheels etc. That being said there are some basic rules to start with and also keep in mind that many tires will work and work well, some will just have different characteristics.
Tread selection: Basic rule of thumb, the harder and more packed the track the lower the tread depth you will want to use. Tracks with lots of loamy loose dirt on top you will want to use a tire that has longer pins so you can dig into the dirt. Again these are basic ideas here.
Compound wise: This also varies with track surface and temperature. Higher ambient temperatures you'll want to use a tire that is a littler harder. Colder temps use a softer tire. Here's a link to Pro Lines compound selection guide:
http://prolineracing.com/images/howt...poundChart.pdf
Also, a good thing to remember is that tire sauce like sticky kicks for example will make your tires softer. Some more than others. Much more in fact. This often allows you to get a tire that is in between compounds. By starting with a harder tire and softening with say WD40...
Everyone please jump in here with their ideas
#35
I've been using WD40 on my tires for a few months now. I've tried it at a couple of tracks and I've noticed it works pretty well most of the time. You really have to let it dry thoroughly. I think it also helps to really work it into the tire with a brush. When I am using slicks I like to use a towel and rub the tire in a spot I've sprayed. My usual process is to apply WD40 on a toothbrush (your moms!) and then put the tires in a ziplock or other sealed bag overnight before I'm headed to the track. Then I will use sticky kicks at the track because it dries much faster.
#36
#38
SDRC is San Diego. Super large indoor track with medium high bite surface. I apply only several minutes before race and leave wet when hitting the track. Takes just a few seconds to burn off excess and then tires hook up really well. I do the same with wd40 when I use it.
#39
They are actually firmer then AKA. I trimmed down the ribbing on the inside to give them a softer feel. The material looks and feels like it will last longer then your normal closed cell foam. I like them alot.
#40
@micah: do you notice any difference if you let them dry first? I've been down to SDRC once or twice but it's been a while. It's a bit of a drive from Burbank! I'll come down again soon I'm sure. I need to show my gf the area. Thanks for your input!
