Tire Tech Talk - Compounds, Wheels, Inserts, Sauce!
#16
Soft and super soft are what they say. Clay tires are a a little different some brands seem a lot softer than others like HB & Panther pink seems more like a super soft to me. JC Gold & PL MC feels a lot harder.
I have found that the clay tire compound really only works on a wetter track with good grip.
Where I race the clay tires either work really well or not at all.
Sorry for all the posts in a row but I have done a lot of tire testing the last few years. That may have something to do with me being broke
#18
What tyre & compound would you suggest for running on mainly loose dirt (not clay) & parts of worn down grass as it is a fairly new track and the grass is not fully worn away yet, thanks.
#19
#20
I would probably look to a good general purpose tire like a Proline Blockade or AKA Enduro. As for compound, cool weather go super soft, warmer go soft.
#21
Should we try and build some kind of chart that lists all the brands and relative hardness levels so we can compare more easily across brands? Excel sheet? Maybe in google docs so we can all contribute? open to ideas….I'm thinking it should be similar to a spring chart. I've seen the on road guys use durometers for foam tires, but I could see this being problematic with rubber tires. We'd probably have to measure before mounting without foam. Maybe we should also be measuring the inserts and charting them as well….
#22
Has anyone used the MIP Stickeez (seems like 3M double sided tape…) to stick their foams to the wheels? Seems this might help with balancing. On that same note, what's your favorite balancing tool?
http://miponline.com/store/mip5115.html
#23
Looks like the new Grey foam from JC is going to be out soon if not now. I have a feeling I'll see it at OCRC, if there is any left after the stock Nats.
http://2wdmod.com/2014/04/22/jconcep...-tech-inserts/
Looks good though! A little softer than red perhaps? Will be nice to have a softer closed cell for 2WD front...
#24
This is an interesting conversion kit for Typo wheels:
http://www.redrc.net/2014/04/aka-110...onversion-kit/
Makes me wonder if I could trim the outside rib of my Durango wheels to run EVO style tires on them.
#25
Question about my evo typos regarding their compound. I have a set of the evo typos, and the bag says clay compound but they feel like a super soft tire. Especially compared to my proline clay compound suburbs. Is aka's clay compound really soft? Or did I get sent a mismarked bag?
#27
#29
#30
Have a question about tire sauce.
I run on low grip, blown out, bumby, dusty tracks.
I have become tired of using too many tires, and now have boxes full of worn down tires.
Are there any tire sauce made for off road outdoor use that could be applied to worn out tires to get some extra laps out of them?
