Schumacher Cougar KF!!!
#1081
I just picked up one of these very unique cars and was wondering if anyone could share some of the weak points with me? also any tips? I know that this thread prolly has them all but honestly iI have no time to read 75+ pages of comments.
Thanks.
Thanks.
#1083
The KF uses some of the same parts or very similar ones.
After a year the car is still as tight as when it was new.
#1085
In about 5 months of running my car on an indoor track where there's no run off and you hit boards and the faces of jumps often, I've only broken one steering knuckle and cracked a lower front bulkhead. By far the strongest car I've ever driven.
-Jeremy
-Jeremy
#1087
i ran mine yesterday for the first time and it was loose. iam running on a short pile astro turf track that is at a sports complex.the problem is the track has a synthetic sand mixed into the turf.not alot but its there. it gets worked out of the grooves after the 1st heat.
the car wanted to snap turn coming out of corners. i had the stock kit set up. ended up changing oil in diff to lighter, raised the pins in the rear and also made the rear camber links shorter. it was better but still did that snap turn. iam also running schumacher mini spikes.
i dont quite understand how to change the rear toe in. do you add washers behind the rear mount?
#1088
#1089
changed out stock diff oil out. went from 125000 cts to durango gear grease. feels close to a ball diff,also running red orings in diff. running stock 35wt oil and stock pistons and springs all around.went up on pin mounting holes in rear,moved upper rear shock mounts all the way in and out on arm.front shock mounts are all stock.rear camber link is short now and all the way in on hub. also moved to short wheel base. car drove better but rear end would still snap around if i didnt baby it.
i went and bought some 4mm washers tonight but unsure how many to add to add a degree of toe in. sounds rudimentary but i was going to match the thickness of stacked washers to a degree on a camber gauge... then use those washers on the rear pivot hanger.
thanks for the help.
#1090
Ways Ive found more grip on my KF:
First and foremost the biggest difference is the low grip conversion
drill pistons to 1.6 holes
reduce ant squat
add rear toe in
lay rear shocks down
lay front shocks down
lower front steering knuckle
raise ride height
lengthen and raise inner link on rear
move shocks to rear of arms
There's quite a bit of things to experiment with to add grip
reduce ant squat
add rear toe in
raise ride height
#1091
reduce ant squat
add rear toe in
raise ride height
reduce ant squat
add rear toe in
raise ride height
#1092
I personally like 37.5F and 35R with black fronts and green rear springs. Invest in the core spring kits when you can.
what front tires are you using? to much front can of course take away your rear traction.
Also make sure no parts are bent, bound up, or even broken.
#1093
Are Schumacher greens the tyre of choice for your track? Is the track indoors or out? I would go to yellows if the track is dry. I know greens are harder than yellows but the compound is different. We find with rear tyres on astro the following;
Schumacher Blues, will work when dry and grip is very good, not as quick as yellows.
Yellows, go to tyre for dry track.
Schumacher Green, can work if the track is greasy but not wet but drying out. Not popular though.
Schumacher Silvers, can work in the wet but not as good as Ballistic Buggy Greens.
Ballistic Buggy Greens, go to tyre for wet/cold/greasy track, will work in the dry but wear too high and not as quick as Schuey Yellows.
Ballistic Buggy Whites, work when the track is drying.
I only really use Schuey Yellows or BB Greens.
#1094
moving the shocks to the rear will slow down the "snappyness" of the rear end. It makes it have more of a plush feel. just what Tony said drill out the rear pistons to 1.6mm and the car will not have any issues of it bouncing when it lands. We have 6 KF's now at our local track and we all did this to our pistons and its an instant difference (rear traction help)
