TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#6392
#6396
#6399
Thanks i will give them a try..Yea know it does seem like the dirt at OC/RC takes no prisoners on tire wear...Does make me miss the dirt that was at west coast.
Gearing for a 9.5... 21-23 ish?
#6400
Club racing tire wear is not typically too bad. For large events when the track takes a lot of rubber it will start to chew stuff up but grip goes way high as well so a give and take. Lots of guys are going to really low tread depth tires as well which does not help with tire wear. (typo, ion, dirtwebs etc).
#6401
Anyone have a good esc setup picture for running the esc in front of a shorty pack in MM? Would it make a difference if I ran the esc behind the battery instead of in front?
#6402
Quick question: What are the differences between using 0 and 5 degree caster on the front?
#6403
hears how most people are running the esc in front of the battery check out frank roots mod on http://www.petitrc.com/setup/losi/Se...ntyTwo2.0.html
#6404
I took my waterfall out for a lil more flex (which helped with forward bite) battery is up against motor not too tight though. its a very tight fit with orion r10 and futaba reciever. low pro servo will help but not a must. ill load pics soon. the elecs you have will def. play a role in how stuff fits
#6405
I seen those pics, but I'm talking about SHORTY PACK setup with esc front..
Frank,
maybe you can post a pic of your setup??
Can you or would you or have you ever put the esc behind the shorty pack?
By the way, I ran your setup Frank last weekend but with the esc on the modified rear tower.. Took 2nd, 1st was not far from me!
Frank,
