TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#6376
RM yes you need the insert that you thread into to hold the front block in place.
MM you tune antisquat with the shims that go under the block just like the RM setup. They have different thickness inserts for MM though as the tranny rests on this insert of MM. If you don't put the corrent insert in that matches the antisquat you will raise or lower the transmission in that area and you don't really want to do that so getting the correct pivot insert to match your antisquat is pretty important when running MM.
#6377
This has been gone over a few times but I wanted to add some more clarity to this.
#6378
Those are just to shim the arms. I normally run my arms forward. The shims are needed as the gap beween the pivots will change depending on the toe settings you run. Run 3 deg you will need more shims then if you run 5 deg of toe, so shim to take out excessive play. Again I shim my arms forward for RM motor setups.
#6379
Thanks for the help
Daryl Boston
#6381
#6383
My 22 2.0 has the Exotek steering rack installed.
The mounting flange on the servo has a small triangle that interferes with the flat mounting surface of the servo brace.
Attachment 1164989
Attachment 1164990
What is the trick to installing the Spektrum servo?
Attachment 1164989
Attachment 1164990
#6384
#6386
After posting my request for instructions, I emailed Exotek and they provided this image.
Instructions from the Exotek for the steering upgrade.
Thank you Exotek as well.
Last edited by bcadman; 02-11-2014 at 03:56 AM. Reason: Exotek provided copy of instructions
#6387
http://sackvillerc.com/2013/07/22/ex...kit-the-build/
#6390
What tires and foam are people using at OC/RC?
