Hot Bodies D413 1/10 4WD Buggy
#1096
@TD
You mentioned 100k for center now, and lower for lower bite.
I'm used to 4wd sc and 8th scale where I go from 5-10 front, 5-10 mid, and 2-5 rear for low to high bite situations. When you say lower, I'm not sure how much you mean.
So, what weights would you start with to tune from for diff weights on low, mid, and high bite across all 3 diffs?
#1098
What body will the kit have? How many pieces?
Also where will be the best place to preorder?, I'm in Australia so will probably buy online somewhere as our local hobby shops don't stock HB.
Justin
Justin
#1100
@TD
#1101
as for the best place to preorder in Australia, our website shows Hobbies Australia as our distributor. www.hobbiesaustralia.com.au
#1103
the kit will come with this body. the body will be in 4 pieces - a nose, a cab, and two sidepods. the cab and sidepods will be bolted together so when you remove the body they come off as one. the nose stays on the car as in some 1/8 buggies.
Justin
#1104
as an alternative ProLine has already made an aftermarket body which consists of 2 pieces - the nose and the main body.
#1105
you'd paint the components separately. the best way is to first assemble the cab and side pods while they're clear so that you can make sure the holes are aligned correctly. then take them apart for painting then finally reassemble them.
Justin
#1106
#1107
#1109
#1110
because I wanted to design in an undercut on the side pods similar to the side pods on an F1 car. with the amount of undercut I wanted it can't be extracted from the mold in one piece. the PL body has a slight undercut but not as dramatic as the kit body.
