Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 07-25-2014, 05:28 AM
  #3826
Matt :-)'s Avatar
Originally Posted by Dstreelm
Nice Paint job!!!
Thanks, here's a better angle.
Matt :-) is offline
Old 07-25-2014, 07:47 AM
  #3827
Trader Rating: 166 (100%+)
Originally Posted by T. Deguzman
esc rear. the wiring is cleaner this way because of shorter wires and you can use a short sensor wire. it also makes it easier to get to the center diff. the battery is full forward to compensate.
I notice your battery leads are really long. Can the lipo not be mounted with the plugs towards the back to allow much shorter leads?
jpcopeland1 is offline
Old 07-25-2014, 09:06 AM
  #3828
lbenton's Avatar
Trader Rating: 48 (100%+)
Where the top chassis plate and the forward part of the rear shock towers attache makes a tight fit for the wires be on the rear of things.
lbenton is offline
Old 07-25-2014, 09:10 AM
  #3829
boudin4evr's Avatar
Trader Rating: 18 (100%+)
crazy question
what is the size tool To tighten locknut that holds piston on shaft
I remember it was very small I think its a 4.5mm
anybody know the size? looking for a wrench for next time
boudin4evr is offline
Old 07-25-2014, 09:15 AM
  #3830
Yeah, just look a closer look, it would block off that outside plug. Could shave off a lot of weight if it wasn't angled. Will try 14 gauge wire instead. Where can I find a fan to mount on the chassis that gets power from my receiver?
Old 07-25-2014, 09:52 AM
  #3831
Team Tekin
yzracer758's Avatar
Originally Posted by boudin4evr
crazy question
4mm
yzracer758 is offline
Old 07-25-2014, 06:21 PM
  #3832
Rybeau40's Avatar
What are you guys doing to take out some steering?
Rybeau40 is offline
Old 07-25-2014, 06:36 PM
  #3833
Matt :-)'s Avatar
You could :
1 - turn the steering gain down on your radio.
2 - add negative camber to your steer tires.
3 - use a front sway bar, or use a thicker one.
4 - increase the weight of your front diff oil.
5 - decrease the weight of your center diff oil.
6 - try different tires.
7 - use a slower steering servo.
8 - raise your front roll center.
Matt :-) is offline
Old 07-25-2014, 07:01 PM
  #3834
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Or take out some rear droop.
RC*PHREAK is offline
Old 07-25-2014, 07:41 PM
  #3835
racer x 1's Avatar
Trader Rating: 27 (100%+)
Just thought id add some color to the thread. Lol havent got a chance to drive mine yet. I did want to ask are ppl shimming the steering bridge?
Attached Thumbnails Hot Bodies D413 1/10 4WD Buggy-image.jpg
racer x 1 is offline
Old 07-25-2014, 07:48 PM
  #3836
racer x 1's Avatar
Under the hood
Old 07-25-2014, 08:34 PM
  #3837
kdeleon's Avatar
For those looking for spurs, in addition to what was offered here, someone has also posted on eBay. Hopefully for those with cars just sitting around can get a new spur and get your car up and running.
kdeleon is offline
Old 07-26-2014, 04:50 AM
  #3838
Trader Rating: 25 (100%+)
1st night went well. Can't believe how hard you can throw this car into the corner. Seems like the car requires a larger motor though. Have you guys noticed this? The same motor I had in my other wheelers seems slow in the 413.... Time to motor up
kerby is offline
Old 07-26-2014, 05:02 AM
  #3839
murky123's Avatar
to me it just feels the other way around. due to this buggy being so light ( mine is 1744 grams )
murky123 is offline
Old 07-26-2014, 06:01 AM
  #3840
It feels more nimble and light. Maybe my others were so hard to drive. Either way I'm motoring up.
kerby is offline
