Hot Bodies D413 1/10 4WD Buggy
#3151
#3152
#3153
#3154
Just got mine back too.
#3155
#3159
ARM Mount clarity
Torrance (guys),
I looked through the forums and did not find info on this. Maybe I missed it, but here we go. Can you please give better clarity on the set up sheets on how (FR) and (FF) are interpreted? The manual shows it one way, but Ty's set up sheet shows the opposite. The image posted shows some confusion. Pleas let me know. Thanks guys.
#3160
Torrance (guys),
#3161
I am in reference to the set up sheet that is included in the manual. I copied the wrong image in my attachment. Although the arm mount references are correct. The car build is very similar to the set up (Included) sheet in the back.
#3162
I think I understand your question, but please correct me if I'm wrong. The setup sheet on page 36 of the manual is also a different setup then the manual kit build instructions. Another example is on the front spindles. Instructions call for 1mm washer on top and 1 mm washer on the bottom, while the setup sheet says 2 mm washer on top. The instructions and setup sheet don't match.
#3163
I have never used the manual when doing the setup of the car. As this setup might be older. Ask your local fast guy or search online for posted setups. Its always your best bet.
Just my 2 cents
#3164
Copy that guys. Just wondering. I followed Ty's Reedy set up. Car is hard to drive. It's darty, and difficult to get on power coming out of turns. Trying to figure this out. Not sure what it might be. Been playing with diff oils. So just wondering.
