Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 07-21-2016, 03:39 AM
  #1846
Default How to remove grease of my gearbox on the lazer zx6
What/how would I remove grease from my gear box easy way.
Rc tuner racer is offline
Old 07-21-2016, 08:49 AM
  #1847
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Did you try spraying it out with motor spray?
Kraig is offline
Old 07-23-2016, 01:08 PM
  #1848
Hello everyone, I present to you my project to add a slipper/differential to the ZX6.
First the slipper/differential, it is made by using some part of the durango DEX410v5 :
Integration in the ZX6 :
The final render :
Lets make it real
3D printed part :
Slipper assembly :
Differential assembly :
Note instead of Durango slipper/differential, we can change diff oil without need of disassemble the slipper clutch
The slipper/differential full assembled :
Everything is ready for the test
Note the steering plate made for easier bump steer adjustement (and it's stronger here than on the hub side)
DarkRedemptor is offline
Old 07-23-2016, 01:28 PM
  #1849
DriveKyosho's Avatar
Trader Rating: 49 (100%+)
The final render :
Lets make it real
3D printed part :
Slipper assembly :
That's impressive! Very nice. How does it preform? What kind of track do you run on?
DriveKyosho is offline
Old 07-23-2016, 11:12 PM
  #1850
I will try this afternoon on my local track (grass, turf and some dirt)
Old 07-24-2016, 12:20 PM
  #1851
First run done :-)
The car can maintain a lot of speed while turning, I need a litle more setup, because she is too agressive in mid turn
Old 07-24-2016, 12:38 PM
  #1852
For all you carpet guys I have a setup issue. I'm running the Tebo world setup on carpet and the rear end seems to jump up going over a couple a little jumps any ideas how to fix this?
gearit is offline
Old 07-24-2016, 08:53 PM
  #1853
Holmberg418's Avatar
You can try alot. Less anti squat, softer rear spring, 2x1.7 rear pistons.
Holmberg418 is offline
Old 07-25-2016, 07:30 AM
  #1854
First run done :-)
So will you be offering the parts for sale, posting up the files to replicate, or just be greedy and taunt us? All are just fine Looks amazing.
scoobyrs25 is offline
Old 07-26-2016, 02:14 PM
  #1855
I'm in holidays with my family, I will give you t dxf for the carbon part and the link printed it on shapeways.
I need to correct the assembly manual to make everything fine ;-)
Old 07-26-2016, 07:21 PM
  #1856
Thank you so much!
Old 07-31-2016, 07:00 AM
  #1857
anyone tried boiling the front arms? if so did it work?
Thompson7 is offline
Old 08-27-2016, 03:08 PM
  #1858
tef
Anyone try mounting the rear shocks to the rear of the car behind the tower and arms, if so can you post a pic?
tef is offline
Old 08-30-2016, 08:42 PM
  #1859
Potoczak's Avatar
Trader Rating: 120 (100%+)
I'm swapping out my chassis to a hd chassis on my zx6. In the bag they give you 2 center drive bones with rubber o rings. Tried to use the bones they gave but they are to short. Has anyone else ran into this issue. Thanks.
Potoczak is offline
Old 08-31-2016, 01:14 PM
  #1860
The 2 they include are the optional bones for mounting the motor mount in the extra postion.
Arcain41 is offline
