Tekno ET48 Thread
#5056
Ah yes, TQ control...I think I'm at a 6 or 7...Don't remember. Kinda of one of those things that I set it and forget it.
#5057
You should be able to wiggle the front cover off at this point, if not, loosen the 2 screws for the top plate of the steering<->diff, and that should allow enough wiggle room.
#5058
Loosen the rear two screws on the diff from the chassis, take the front 2 out (2.5m's). Then take the screw out for the bumper (IIRC 2.5 also), behind the bumper are 2 long screws that go through the a block and into the diff housing. (2mm), I then usually take the 2 screws to take the sway bar bracket off. (2.5mm) And the 2 screws in the top of the front cover for the diff housing.
#5059
#5062
Can someone get me the length of the rear center shaft?
Thanks in advance.
Thanks in advance.
#5064
Thanks you.
#5065
hey guys have you seen the big price drop on towerhobbies i got a email from they dam
#5067
Something new must be coming but at this point besides hubs and springs what else can they change
#5068
#5070
Yeah the buggy is allways being tweaked. The truggy has been great so i think they leave it alone.
