Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 01-14-2016 | 07:36 AM
  #4681
Suspended
Default .
so there truggy is all complete but i ran into two issues. im new to electric so its difficult for me.
1) for some reason my servo wire isn't long enough to reach to the radio box. on everyone else et48 it reaches no problem.
2) I feel like the battery straps are WAY to long and i wouldn't have a good Velcro grip, are their smaller straps?
jshum610994 is offline
Old 01-14-2016 | 08:30 AM
  #4682
mkl
I run Spektrum servos as well and the servo lead is too short for Tekno vehicles. Use a short 3" servo lead extension and you are all set.
The battery straps are long, but when you get a hard case 4s battery, they work and hold well.
Also, ditch the plastic servo horn. Get a Tekno alu horn, they work great and are strong. The big truggy tires will strip that horn quickly in a crash.
mkl is offline
Old 01-20-2016 | 07:37 PM
  #4683
justpoet's Avatar
Originally Posted by HollywoodRC
Ok, my Truggy Gurus......I am planning on running a Tekin RX8 with a 1350Kv motor on SMC 6V 4300mah. I always wanted to run 6V in my buggy but didn't because of ROAR. I do not plan on running ROAR with the Truggy. I hope this will be a good combination. What pinion do you guys recommend? The track I will be running , Thornhill, is the largest track in North America.
That KV on 6s should gear almost identical to a 4s 2000kv. I would probably start with a 16t but have 15t for smaller tracks.
justpoet is offline
Old 01-21-2016 | 10:19 AM
  #4684
Guys is this thread for the ET48 in general or only v1? Is there ET48.1 .2 and .3 like the buggy?
Love the layout. Not a fan of the other electrics with a wide nitro like chassis
spawn_x is offline
Old 01-21-2016 | 10:28 AM
  #4685
I believe this is the only ET48 thread. Not a huge difference between the ET48 and the ET48.3 anyways.
ezlight is offline
Old 01-21-2016 | 10:29 AM
  #4686
justpoet's Avatar
This thread encompasses them all.
justpoet is offline
Old 01-21-2016 | 10:36 PM
  #4687
Cool.
This doesn't seem to be a very popular e-truggy, should that concern me in any way (parts availability?)? I'm seeing tons of Losi parts on ebay (duh) and worried that parts will be difficult to obtain few years from now (I'm not a racer who needs the latest and greatest, so I might keep this one for 5-10 years).
spawn_x is offline
Old 01-21-2016 | 11:14 PM
  #4688
Mate this is one best truggy there is out and it's big
coombes is offline
Old 01-22-2016 | 06:50 AM
  #4689
mkl
Cool.
At least in my area they are very popular. At the last major race I went to there were basically 4 brands represented in a pretty big turn out, Losi, Durango, Tekno and Mugen. Tekno being the most popular by far.
I would not be concerned about parts availability.
My truggy is one of the most fun RC's I own.
mkl is offline
Old 01-22-2016 | 11:52 AM
  #4690
Slapjack's Avatar
I have a question about my shocks and if I have them setup right. I think I just have the springs on it that came in the kit (green). But when I set the truck on the bench there is no droop... like the truck doesn't settle/sag and the shocks don't compress at all like my 10th scale buggies. I have the same issue with my EB48.2. Is that normal or should it compress some when its set down? Do I need to just get lighter springs maybe?
Slapjack is offline
Old 01-23-2016 | 05:58 AM
  #4691
WonTonsChicken's Avatar
Did you ream the arms?? The hinge pin shoul fall threw.. Not have to be pushed
WonTonsChicken is offline
Old 01-23-2016 | 07:17 AM
  #4692
Slapjack's Avatar
No I did not team the Arms. On the et or the eb. But I didn't do that on my 10th scales either and those droop some when set down. What size reamer do you use on the truggy? 4mm? I am in the process of ordering all new tools and I was looking at the 3 and 4mm reamers. What about oil weight piston and springs? What should I be running for all that? Right now everything is straight oout of the box
Slapjack is offline
Old 01-23-2016 | 09:41 AM
  #4693
RC Matt's Avatar
What kv motors do you guys use because I may get one of these in the future. Also is this more durable than the eb48.3 and is there really a difference between versions of this truggy. Thanks.
RC Matt is offline
Old 01-23-2016 | 06:51 PM
  #4694
What is your shock length front and rear?
qstorm777 is offline
Old 01-23-2016 | 07:50 PM
  #4695
justpoet's Avatar
If you get a reamer, get a 4mm one. Another common way is a drill bit (#22 I think, but don't quote me). That being said, now we're often cutting the arms when new so that the middle of the hinge pin is open, which also makes them free without reaming.
justpoet is offline
