Shorty Packs
#17
Shorty packs
Dirt Cheap RC has 4000 75c shortys from Vant battery, I've been using them for about 6months now and they're a great battery http://thebarnfloor.com/catalog/prod...5#.UXiEWqKmiAh
They're out of them right now but will be back in stock soon.
#25
SMC has a 4600 for 49.95$.
http://www.smc-racing.net/index.php?...product_id=127
I think once you see shorty pack go to say 5200, they will be the norm in 10th.
#28
I'm not completely sure how that works. The Pro4 4600kv is good for 2s, but is not rated for 4s. The RX8 will handle it fine. I guess if you ran dual shorties to double mah instead of voltage, you might be able to use it in an ebuggy, but I think the heat and loss of torque would outweigh the benefits of a little bit lighter motor. I ran a 4600 with dual shorties in my old SC10 4X4 but wouldn't ever consider it for ebuggy.
I am running full size 6000's in my 811 right now. After a 10 min main, I put back in about 2800mah into each pack. I am not sure how much you can pull out of a Shorty before lipo cutoff though. That is a medium size outdoor track. I would think the 4600 ProMatches might suffice. I am running a T8 1900 also.
#29
Tech Legend
I would say you would look at the new Pro4 HD line of motors from Tekin, probably the 4300Kv one on 2S. From what I have been reading about it in SCT usage in a Tekno SCT410 which is one of the heavier 4x4 SCTs, it works excellent, tons of torque which from what I recall the differences I noticed between the 1900Kv and the 2050Kv Tekin, that is probably what you would want.
As mentioned by others, you then would wire it up in parallel for more runtime. Getting easily over 10 minutes with the 7200mah 2S pack from Promatch with the Pro4 4600KV motor, I would assume you would be able to do the same with 9200mah effectively.
If your track is strict on weight, that extra heft of that motor could help too when running the dual shorties.
