Hobby Pro USA PR S1 2wd Buggy ALL NEW
#1201
Besides the hobbypro brand, what aluminum wheel hexes are yall using?
#1202
Does anyone know the size of the thrust balls. I currently building the 2014 car and I was like to replace the kit thrust balls for ceramic thrust balls.
#1204
Hey guys I think I'm going to go ahead and swap my buggy over to MM. I've never ran a MM buggy so I have to ask... Do you guys have any setup tips? I'm running an 8.5, would gearing likely be close to what I currently use? I'll also be switching to a gear diff since the ball diff is shot until parts come in, what diff fluid are you guys running on a medium to high traction track? Thanks in advance!
#1206
#1208
#1209
Trader Rating: 53 (100%+)
Do B4.2 front and rear wheels fit this buggy? I'm on the fence with pulling the trigger on this buggy and this might help sway me .
#1211
Ok now a caged ceramic thrust bearing is what I would like. I also plan on removing the bearing shields on the internal bearing of the ball diff. I'm basically trying to get this ball diff as close to the schumacher ball diff. The schumie ball diff was hands down the smoothest ball diff I have ever used in 25 years of being in RC. Once again thank you for the help and I will order from TSR, kind of feel guility if I don't since their one of my dealers.
#1212
#1214
Your gearing will not change from RM to MM. As far as build tips, move your esc to directly behind the servo and the battery as far back towards the motor as you can. Depending on how rough or smooth your track is would change shock oil. I currently run 32.5 f and 27.5r with 2 hole 1.6 pistons and kyosho pink front springs and white rear. This setup has seemed to work everywhere from high bite to low bite, but I have also ran 27.5 f 25r with kyosho gold rear springs and liked it as well. As far as the gear diff I just pack it as full as I can with the black grease and you're set. Only advice I can give is when you first drive it don't point and shoot, just carry speed and ease into the throttle and you shouldn't have any trouble
