Tekin Pro 4 HD Factory Thread
#676
SCVRC in Santa Clarita, Southern California is where I ran, It's smaller (I believe) than OCRC Raceway. How do I go about connecting the Hotwire if I have the gen 1 hotwire and a Gen 2 ESC? Also, how should I connect the motor cooling fan, to receiver or the ESC?
Thanks again!
Thanks again!
If you plan on running a motor fan, attach it to the receiver. IF you're running an HV servo, make sure your motor fan can handle 7.2v, I've seen some blow up due to the higher voltage.
#677
Thank you - exactly the answer I was looking for! Yeah - the bottom end of the power was a little concerning without the cable, but I just factored it into my thinking. Anyway - should have the cable here in about 2-3 hours, so my situation shall soon be rectified
You can run it that way but you are missing out on smooth bottom end power. Lots of money and r&d has gone into these things to achieve that and you have spend the big bucks to get it... so run a sensor wire. If the wire is not there or breaks while running the esc switches to sensorless so you can run it till you get a wire.
Motors come with sensor wires but they are not 1 size fits all. There are tons of different lengths so pick one up that is the correct length.
It is a rare occasion when I use the supplied wire, I like a clean wiring job and that means picking up a sensor wire that's just the right length.
#678
Randy! Thanks for the insight, never thought of the voltage as it relates to the fan!!! Attention to detail!
The Gen1 Hotwire will connect to the Gen2 Rx8 via the programming port or the servo lead, whichever you prefer. The esc should have came with the proper adapter.
#679
Hi guys - new here. Anyway, I picked up a SCTE 2.0 and got my hands on a rx8 gen2/4300 HD. The sensor cable that came with it was decidedly short, so I did a little googling to make sure it was safe, then just ran the setup sensor less. It cogged a little here and there but nothing too bad. Didn't run it too hard but ran maybe 7 packs through it.
I should be getting a sensor cable that's long enough tomorrow, can I just plug it in and play? Or is something going to need to be adjusted on the ESC?
Thanks in advance guys!
#680
Randy,
Looking for advice. Planing on running the new desc10 with 4s. What motor would you recommend? The pro 4 1900, the pro 4 1850, or the pro 4 2400?
Mainly outside, low traction, medium sized layout. I'm leaning toward the 540 cans, but just wanted the expert opinion.
#681
Can you run 2S lipo on the Pro4 HD 3000kv motor? I am looking to put it in a Slash 4x4 ebuggy conversion. I have all 2s lips currently but plan to purchase a 3s lipo with my new motor but do not want to be limited to just 3S lipos in my slash.
#682
ez access port
Hey I picked up a used rx8 gen2. It doesn't have the wire to connect the ez access port to the hotwire. I have the hotwire gen 1. Does anyone know what cable I would need to use the ez access port? Can I just pick up a cable from an electronics retailer like frys or the like? Could I DIY one? Suggestions? Does anyone have a pic of the cable? Phew wall of questions! thanks guys!
#684
Randy,
#685
Not sure about the others but I run the Pro4HD 1850kv on a small (2s size) 4s pack in my Tekno Eb48SL. Super smooth/runs cool/good power and really good run times for my 4s packs only being 3600mah. I love the setup and would use it for sure in my 4wd SCT if I could. Just my thoughts but not a "expert" so I'm sure Randy will chime in.
I am looking for a bit more motor RPM with the 1850kv @ 27k to 31k.
I pulled the trigger on a ROC 2300kv and that will put me @ 34k to 38k.
I was gonna try the 2500kv Pro4 HD, but it seems a bit too much for 4S and too low for 3S.
#686
Pro4 hd 4300
I had one of these go on me Sat (granted it was 2.5 years old). It looks like the rotor had enough (Things holding the magnets on the back end came loose and one of the magnets is loose). Are there any warning signs before a rotor goes or before the motor goes?
#689
#690
Hey guys, looking to put an RX8 Gen2 with a Pro4HD into a Yeti kit with stock gearing.
I was thinking of running the 2500kV to give me good torque and some reasonable speed but not too much.
What kind of current draw should I expect? Looking for some 2S / 3S LiPo spec recommendations. I've read in this thread that the current draw is obviously variable but can peak out around 200 amps. So I would need between 35-50C 6000-4000.
Now just need to choose a reasonable make to give me some reasonable reliability.
