Lipo Low Voltage
#32
Jimmy O you keep referring to the charger as your possible problem, I have two of the same those chargers and have never had an single issue with them. Lipos take extra care, you don't want to store them more than a day or two discharged or fully charged, a "storage charge" is best which your charger is capable of lipos should be stored at 60-70 percent for any extended period of time
#33
I use 3,2v lipo cut off and 97% of charge at 3C. I prefer having less lipos but good ones that I can charge fast rather than more that are slow to charge. I never charge my lipos at 100% because it's the balancing that takes time at the end, it's also better for the lipo life.
It's been 3 years I charge at 3C, I puffed one single lipo and it was a cheap one. This running 3 categories and considering my gf races with the same lipos also.
#35
Storing at full charge tends to raise the Internal Resistance, and can cause puffing. My experience (mostly the IR) and that of many others.
#36
#37
They are not saying the same thing or opposite things. One is referring to how much the lipo is charged to; the second is talking about leaving a charged lipo setting.
Leaving a fully charged or fully discharged lipo set for weeks= trouble
Leaving a lipo plugged in for weeks=dead lipo (in most cases)
#38
Depends on what it's plugged into. If the component has a mechanical switch then it makes no difference. I've left a partially charged lipo plugged in and sitting for months and had no issues. If there is a draw in the component then it'd be a different story. Fast way to check is to put an ohm meter to the battery contact of the speed control, with the switch off, it should read +/-0.00.
#39
The second is suggesting a full charge for a couple weeks is no big deal. (full probably means 4.2V to most, but I doubt if 4.18 for a couple weeks is much better)
Sorry, I view that as being contradictory and opposite.
#41
Apparently, you are missing something. Read it again. Full charge (4.20v/cell) for two weeks...no problem. Stopping the charge at 4.18v/cell is to [B]make them last longer[B]. Topping off a lipo on every charge cycle will shorten it's life quicker than if you stopped the charge at 4.18v/cell. I didn't contradict anything that I said. Storing for up to two weeks at either voltage level will not do any harm.
#42
LIKE IVE STATED BEFORE....i have always stored my lipos at full charge(500mah) and have never had a single problem....so idk what everyone is yapin about that, it could be just the lipos that r dif,,idk!!
#44
Great to have it fixed eh
