Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-14-2013 | 07:42 PM
  #10501
1mrdad's Avatar
Originally Posted by kyoshoracer77
Do they got a hole for the big toe to stick out??
Yes, but I had to do the toe mod using a dremel tool to get the correct size hole without burrs.
1mrdad is offline
Old 10-14-2013 | 10:34 PM
  #10502
is it ok to use CA glue on my bullets to keep the plastic cover on them?
xTotalghost is offline
Old 10-15-2013 | 12:25 AM
  #10503
Cridd's Avatar
Originally Posted by Mizchief
I'm sure they are great guys, but as a professional web developer I can't give such a horrible site my business.
It was rough but it worked and took Paypal. It was like taking a step back a few decades.
Cridd is offline
Old 10-15-2013 | 03:52 AM
  #10504
t0p_sh0tta's Avatar
Originally Posted by 1mrdad
The outdrives/dogbones are brand new. My socks are the same length but old and smelly...
Lol, pull off your rear arms and set them on a flat surface. I've seen the get warped from time to time.
t0p_sh0tta is offline
Old 10-15-2013 | 04:47 AM
  #10505
BIGSKI15's Avatar
I saw alex miller at mcculloughs for the race against cancer. He is fast without a doubt. He took third with Marsh in 1st and Wilks in second.
Originally Posted by Bob Barry
He got lit up by the Alex's
Alex Miller came with me. He's a Harrisburg PA local ( Bumps and Jumps).
Alex K is another up and comer from the north east. I forget which track is his home track.
These two kids didn't luck into their spots either. They were blazing fast in 2wd and 4wd all weekend and the results showed.
BIGSKI15 is offline
Old 10-15-2013 | 08:30 AM
  #10506
1mrdad's Avatar
The arms are brand new. I just completed my rebuild for the upcoming indoor season. The arms, hubs, ball cups, and bearings are all brand new. The shocks were rebuilt, new springs, new caps, new ball ends and eyelets installed and checked on a Losi shock tool. Everything cleaned and lubed. What is a mystery to me is that the car was doing the same thing prior to the rebuild. This morning I discovered that the gear diff was binding in the transmission case when the case was bolted to the motor plate. (I had been running a gear diff for the last year, and I am planning on switching back to a ball diff when the parts arrive) I tried an old ball diff, and it spun freely; so I assume the gear diff and cover must be tweaked. I'm gong to try the car at practice tonight with the ball diff to see if the problem is corrected.
1mrdad is offline
Old 10-15-2013 | 08:42 AM
  #10507
huzzler's Avatar
I don't see why not. As long as you don't get any inside the bullet. Shrink wrap works good too. That's what I use on my bullets.
huzzler is offline
Old 10-15-2013 | 08:57 AM
  #10508
Ryan got caught up in traffic in the main of 2wd. Me and Alex K. Were together for a good part of the race. I wrecked over the table tops in the middle of the track, and then the other Alex wrecked in the next corner after the double double. Dustin was about 10 seconds in front of us by the end of the race.
Millerracing is offline
Old 10-15-2013 | 09:10 AM
  #10509
t0p_sh0tta's Avatar
^certified fast guy. I get whooped by the other Alex on a weekly basis (he can't beat me in 8th scale though)!
Old 10-15-2013 | 10:53 AM
  #10510
Captcha's Avatar
Just use liquid duct tape. We use it on all of our solder joints. Works great, and when you put heat to it, it melts away not catches on fire like the CA glue will.
Captcha is offline
Old 10-15-2013 | 05:50 PM
  #10511
I just got the avid top shelf and have a hobby wing v3.1. I am having trouble getting the speedo to fit without rubbing the body? Anyone used this combo before that can share how they got it to fit?
The speedo has posts on top so putting the wires under would be challenging...
gguertin145 is offline
Old 10-15-2013 | 06:13 PM
  #10512
Jmuck69's Avatar
I removed the standoffs which add 4mm of height and used a longer 5/40 screw (9/16) along with a .5mm shim as a washer. I put a 1mm washer inbetween the ESC tray and the brace to make it level with the cut down lipo strap. My Orion R10 was rubbing against the body and this should fix it and make a lower CG ride. Orion will go in tomorrow.
Jmuck69 is offline
Old 10-15-2013 | 06:34 PM
  #10513
so got access to a 3D printed and going to make some aarms for my b4.2 mabey they might be better
Old 10-15-2013 | 06:38 PM
  #10514
much better!
Thank you jmuck!
Old 10-15-2013 | 08:03 PM
  #10515
t0p_sh0tta's Avatar
What's wrong with the arms currently available?
