Team Associated B4.2 Thread >
Like Tree4Likes
Old 02-01-2013 | 01:59 PM
  #1036
Razathorn's Avatar
Originally Posted by turbo2cam
Why does it seem dumb? I wasn't kidding about my oil pan analogy. Oil pan drain bolts don't use o-rings, and they don't leak. Same with transmission drain plugs. If the oil is thicker than the slop in the threads, the oil won't be able to seep out through the threads. (this is why these drain bolts are UNF threads instead of UNC threads...but those are extreme cases as the hole thats being plugged, is MUCH larger than what we are talking about here.) So if you are leaking, you either running really thin oil, or your threads are fubared...or you are just magic lol
Actually, oil pan drain plugs DO use washers, at least mine, and most I've owned. It uses an M14 aluminum crush washer. Others use things like fiber washers or rubber coated copper washers. I have one that does leak in fact, from the plug threads, slowly. I started using rubber coated washers and using my own "torque spec" because I stripped an aluminum pan out using a torque wrench and new alu crush washer as specified and now I don't trust honda's manuals at all. I had to throw a single oversized plug in there and a nylon washer. It still leaks a few drops a week.
Really depends on the threads and the case. I want nylon screws
Razathorn is offline
Old 02-01-2013 | 02:00 PM
  #1037
turbo2cam's Avatar
Originally Posted by Wild Cherry
Think its rather important to make clear no bleed seal = oil leak
Not arguing , debating or even stating a personal preference.
Sorry if I stepped on few toes ...
Just feel its important to make sure others here realize what happens when you don't use a bleed seal ...
"Think its rather important to make clear" that this is YOUR opinion...not FACT.
Either way, I'm leaving work to go pick up my B4.2 right now, so keep on keepin on rctech lol
turbo2cam is offline
Old 02-01-2013 | 02:01 PM
  #1038
racer1812's Avatar
Super Moderator
Think its rather important to make clear no bleed seal = oil leak for me
Just feel its important to make sure others here realize what happens when I don't use a bleed seal ...
some say they leak, some say they don't. Can't prove one or the other wrong over the web.
Posting ones personal experience doesn't mean it will be the same for everyone else.
racer1812 is offline
Old 02-01-2013 | 02:02 PM
  #1039
Cain's Avatar
Tech Legend
Originally Posted by Cridd
+1 some people have leaky holes and some don't!!
I heard Olestra used to cause that ...
Cain is offline
  #1040
Cridd's Avatar
Turbo post some pics of the new towers, curious on the finish work.
Cridd is offline
Old 02-01-2013 | 02:04 PM
  #1041
turbo2cam's Avatar
My families business does literally thousands upon thousands of oil changes on honda\acura's. Using an alum. crush washer on each one. no rubber grommet, no fibers, no nothing...why? because its a CRUSH washer. not a grommet or a seal...a washer.
If you stripped it when tq'ing to factory spec....odds are it was fubared before you got to it...yes?
The factory sells each and every car this way, and assembles, and maintains them all this way....just sayin'
Old 02-01-2013 | 02:05 PM
  #1042
turbo2cam's Avatar
Will do!
Old 02-01-2013 | 02:06 PM
  #1043
Wild Cherry's Avatar
Tech Legend
The picture posted shows the leak in question ...
The oil leaking from the bleed screw is proof ...
Also have two other sets of 12mm shocks with copper seals that have stayed dry & never leak a drop ....
I can't do anymore then post pictures of and inform the results .....
Have zero intentions to be here call-n out others about ...
Wild Cherry is offline
Old 02-01-2013 | 02:12 PM
  #1044
Jmuck69's Avatar
Good lord I hated the Lays chips with Olestra...
Jmuck69 is offline
Old 02-01-2013 | 03:18 PM
  #1045
turbo2cam's Avatar
Ahhh..the wait is over, now the build begins!
and the front shock towers....
I just happened to have a NIB b4.1 front shock tower, so I took some crappy cell pictures of the new vs old.
New B4.2 on the left, old B4.1 on the right.
Only difference I see visually and dimensionally, is the "pad" where the upper shock mount holes are, is thicker on the B4.2.
B4.2 = .283"
vs
B4.1 = .204"
So basically B4.2 tower is the same as having a 2mm spacer on a B4.1 tower.
Nothing is shaved, or changed for added clearance, the ONLY change I see is the pad being thicker by .079 (2mm) and the pad is thicker on the inside of the tower (shock mount side)
Again, B4.2 on the left, B4.1 on the right.
Old 02-01-2013 | 03:24 PM
  #1046
turbo2cam's Avatar
Maybe you just didnt clean them up properly after removing washers and re-bleed? Here is a pic I just took of my son's B44.1 which has a practice day, and a full race day (with both of us driving it, in 2 different classes) and I built them with NO O-RINGS and as you can see...NO LEAKS.
All four of them are identical..I can post pics of all 4 now that I have the car in front of me.
Just because yours failed to seal, doesn't mean that they ALL are that way. Operator error is what I would chaulk this up too...but thats just me.
Old 02-01-2013 | 05:14 PM
  #1047
Wildcat1971's Avatar
rear tower pics pleasors
Wildcat1971 is offline
Old 02-01-2013 | 05:18 PM
  #1048
Razathorn's Avatar
Nope. I've done nearly every oil change on this car and used a new crush washer and torque wrench. It was good. Just an aluminum pan. Sometimes it happens. Every oil change since 30k. Car's at 111k now--single oversized plug, drip drip
Old 02-01-2013 | 05:43 PM
  #1049
I feel dumb. I forgot the c clips in the front axles so how in the world do I disassemble them to put them in? To clarify, the front knuckles have the bearings and axle installed, without the c clips. I can't figure out how to take the axle out without damaging the knuckle!
SC8E is offline
Old 02-01-2013 | 05:46 PM
  #1050
1) remove the hex
2) take out the axle pin
3) push the axle out.
4) remove the inside bearing.
5) put the bearing on the axle and push it all the way on
6) install the c clip
7) line up the c clip with the "D" shape inside the hub adn press the axle through
8) insert the axle pin and the hex
