Team Associated B4.2 Thread >
Like Tree4Likes
Old 02-01-2013 | 12:42 PM
  #1021
Eli's Avatar
Eli
I think he was being sarcastic Kraig. Without a sarcastic font it could be taken wrong.
Eli is offline
Old 02-01-2013 | 12:52 PM
  #1022
turbo2cam's Avatar
Originally Posted by Razathorn
I definitely want to try other sealing solutions because running nothing still seems kinda dumb.
Why does it seem dumb? I wasn't kidding about my oil pan analogy. Oil pan drain bolts don't use o-rings, and they don't leak. Same with transmission drain plugs. If the oil is thicker than the slop in the threads, the oil won't be able to seep out through the threads. (this is why these drain bolts are UNF threads instead of UNC threads...but those are extreme cases as the hole thats being plugged, is MUCH larger than what we are talking about here.) So if you are leaking, you either running really thin oil, or your threads are fubared...or you are just magic lol
turbo2cam is offline
Old 02-01-2013 | 12:58 PM
  #1023
Eli's Avatar
Eli
Umm, depends on the oil drain plug, 99% of the 1:1 cars i work on use some sort of rubber or copper gasket. If the manufactuer doesnt use a form of gasket its most likely due to the design of the bolt where they taper and seal off that way similar to what you would see in a plumbing system.
Eli is offline
Old 02-01-2013 | 01:25 PM
  #1024
I've changed a LOT of oil in a lot of cars, though it's been a while.
Oil pan drain bolts certainly did use o-rings, and they still do.
kevinrc is offline
Old 02-01-2013 | 01:27 PM
  #1025
fullsyzz's Avatar
All this talk about plugging holes is making me excited!
fullsyzz is offline
Old 02-01-2013 | 01:29 PM
  #1026
Cridd's Avatar
Default B4.2 shock towers
anybody have any pictures, there has to be somebody that can post a picture of theirs all put together??
Cridd is offline
Old 02-01-2013 | 01:40 PM
  #1027
Wild Cherry's Avatar
Tech Legend
Some one said try it .....(no bleed seal )
I did just that and posted back the results with a picture ....
I did snug down the screw firmly ..
All 4 shocks leak the same amount ....
Not like one leaks and the rest are dry ...
If just one or two shocks were dry ?
Maybe I could accept the story's claimed by some here ....
Now installing the copper seal because I found out the hard way which method works .....
Wild Cherry is offline
Old 02-01-2013 | 01:44 PM
  #1028
Waflet's Avatar
Hideeho
Now that's just wrong
Waflet is offline
Old 02-01-2013 | 01:46 PM
  #1029
turbo2cam's Avatar
My family owns a honda/acura repair shop...dad has been working on honda's for 36 years now. They don't use any sort of gasket at all. period. drain bolt, and crush washer. that's it. same on the transmission. So I know for a fact, that every honda/acura on the road, does NOT use any sort of gasket. (that's a lot of cars!) And no they are not using pipe taps in their design. (tapered threads) And before anyone says the crush washer is the seal...it's not, it's only purpose is to absorb the tq from tightening the bolt down as to not strip the threads in the 18ga steel oil pan.
Now, from my aerospace experience...if you truly want to have an o-ring as a seal, you need to have a groove machined out for the o-ring to sit in. If not, the o-ring will ALWAYS get twisted up, and will not seal. The shocks are not designed as an o-ring seal (at least not functionally anyways) a crush washer (the brass losi ones that people refer too) is most likely the way to go here...but as long as you don't overtighten the screw, and strip the threads...its exactly the same seal as my oil pan/trans analogy.
http://www.hondaautomotiveparts.com/...3sr801_e14.png
#036 WASHER, DRAIN PLUG (14MM)
#022 BOLT, DRAIN PLUG (14MM)
^^ no o-ring at all. straight from Honda.
Old 02-01-2013 | 01:47 PM
  #1030
Wildcat1971's Avatar
Originally Posted by Wild Cherry
me too have 3 rides...
just one ride with out the seal's, thought I try as you are .
All four shocks are leaking ...
will be installing the copper seal to correct
so what am i looking at here
Wildcat1971 is offline
Old 02-01-2013 | 01:51 PM
  #1031
Tradin Paint's Avatar
Ok some people like running some type of seal and some don't. Run what you like and stop all this back and fouth crap
Tradin Paint is offline
Old 02-01-2013 | 01:53 PM
  #1032
Back in the day when we had to change oil every 1,000 miles, NONE of the cars I owned had an O ring around the oil drain plug.
shagnat is offline
Old 02-01-2013 | 01:55 PM
  #1033
Cridd's Avatar
+1 some people have leaky holes and some don't!! Personal preference on how you plug your holes to stop the leaky leaky.
Cridd is offline
Old 02-01-2013 | 01:57 PM
  #1034
Tech Legend
Think its rather important to make clear no bleed seal = oil leak
Not arguing , debating or even stating a personal preference.
Sorry if I stepped on a few toes ...
Just feel its important to make sure others here realize what happens when you don't use a bleed seal ...
  #1035
turbo2cam's Avatar
