Team Associated B4.2 Thread >
Like Tree4Likes
Old 08-21-2013 | 12:30 PM
  #8446
i think ABS is a bit like PWM controlled braking/accelerating with the intensity of ABS depending on how fast you move the throttle. Punch-control on the esc also works like PWM ABS
Cody227 is offline
Old 08-21-2013 | 12:32 PM
  #8447
Wildcat1971's Avatar
well, yeah you can always "say" just use your finger. My throttle finger is fine, but its retarded on the brake side. And on lower bite a light tap will spin you out. So in the past, I just set my drag brake for the surface and just off power with drag break in the corners. ABS on the rc does not have feedback. it has pulses that you can adjust the intervals, strength and engage points on. I have played with my epa's and I am not convinced they dont mess up other things. I have also been using the expo on the break side also. And it is ok. Many people dont use some of the advanced radio features and granted some are designed for nitro. For instance many of the better esc's have both punch control and expo. They both limit the power you put down, but in different ways. Some just use punch control and others just use expo and some use a combination.
Wildcat1971 is offline
Old 08-21-2013 | 12:34 PM
  #8448
ryanpatrickgore's Avatar
Originally Posted by Cain
got the RPM B4 a-arms in. Initial overview of them (visual, no installs yet) they look pretty beefy which is to be expected from RPM. by comparison to what I remember on the Durango buggy I had briefly, they seem similar in thickness.
Will report back as soon as I have more info ...
how do they flex in your hand vs the stock arms? usually rpm seems more flexible. this could mean more traction??
ryanpatrickgore is offline
Old 08-21-2013 | 12:35 PM
  #8449
Suspended
The expo on my radio makes things "lag" way to much!!
theblitzkidd is offline
Old 08-21-2013 | 12:36 PM
  #8450
Originally Posted by ebay007
about a month ego after driving the brand new b4.2 for about 3.5 packs i saw that my chassis had two cracks near the servo:
because it was a new car i didn't drive hard (i still don't). only getting to know the track and the car.
so i emailed associated and they agreed to send me a new chassis.
so nice CS from AE.
did this ever happened to any one?
I snapped 2 chassis right off, but in front of the servo. Both were caused by direct hits, so nothing to complain about. This looks like bad processing during the injection moulding.
Pellefa is offline
Old 08-21-2013 | 12:43 PM
  #8451
if i get these it will be for my kid. A little extra flex is fine and we race out doors. So stiffer is not always better for us. I am concerned about the binding. On my kids sc10, if you life the arm with the shock off, it stays up. I have tried to file it down, but it was not good. I didnt have a a-arm hinge pin reamer, so maybe thats the ticket.
Old 08-21-2013 | 12:45 PM
  #8452
Suspended
My t4 did that with the rpm arms, I fixed it with a drill bit!!
Old 08-21-2013 | 12:46 PM
  #8453
the incubus's Avatar
Actually, the location of these fractures suggests hard landings on the chassis towards the front of the battery tray. Land on the chassis enough times at speed and you slowly stress the ribs until the can't handle it anymore and the result are these types of stress fractures.
the incubus is offline
Old 08-21-2013 | 12:48 PM
  #8454
The new RPM arms are supposed to be installed with the RPM Bulkhead.
Old 08-21-2013 | 12:52 PM
  #8455
Suspended
Ohhh well I wish I would have known heehee
Old 08-21-2013 | 12:58 PM
  #8456
Right from their site:
B4, B4.1 & B4.2 Front A-arms & Bulkhead
RPM A-arms for the Associated B4, B4.1 & B4.2 were designed to solve several customer-related complaints about the stock A-arms. Foremost is durability. Our B4 front A-arms are designed to withstand some serious abuse! We’ve redesigned the entire front end, replacing the stock front bulkhead with a version that helps spread impact forces over a larger area at the inner hinge pin mounts. RPM front A-arms are wider at the inner hinge pin by nearly 3/16” without altering suspension geometry.
We also focused on the hinge pin retaining system used on the stock A-arms. Using a small screw hole so close to the hinge pin like the stock arms do creates structural weaknesses. We moved the hinge pin retaining screws in-line with the hinge pins, significantly strengthening our A-arms in the process. By eliminating the smaller 2-56 hinge pin retaining screws, we’ve also eliminated the problem of the hinge pins falling out due to varying screw head diameters.
Our final focus was on slop elimination. Our strict quality control allows us to tighten up all of our tolerances without fear of binding the suspension system. The final result: a smooth, free moving suspension system with minimal slop. Our tighter tolerances on our A-arms allows other critical adjustments such as camber and toe angles to be much more consistent, which provides better and more consistent control of the B4.
RPM B4 A-arms come with all necessary mounting hardware and instructions. RPM B4 A-arms are sold in pairs and include the front bulkhead.
Tech Notes: RPM B4 Front A-arms require the use of the bulkhead we supply in the kit. Stock or any other aftermarket bulkheads will not work with RPM A-arms.
Old 08-21-2013 | 01:09 PM
  #8457
yeah, the sc10 required the rpm bulkhead too. She would probably just start breaking the caster blocks and hubs next, lol. Although that never really happened much on the sc10, maybe the extra arm flex helps. I will stick with the stock arms, but for her they would be good.
Old 08-21-2013 | 01:26 PM
  #8458
there is no way it happened this way. the front weighs very little.
ebay007 is offline
Old 08-21-2013 | 01:32 PM
  #8459
does not really mater, AE stepped up and is sending him a new chassis. AE has stepped up every time I had an issue. They even replaced my exploded reedy sonic rotor for free even though i was past the warranty period. Didn't even charge me the shipping to get the new rotor here. The only issues I have with AE are mostly likely TT's fault. I just hope TT does not kill AE.
Old 08-21-2013 | 01:39 PM
  #8460
i all ready got it. just waited to see how it end up.
ebay007 is offline
