Team Associated B4.2 Thread
#7411
#7414
This looks way cool.
http://www.lrp.cc/en/products/sanwa/...egler/details/
Why is LRP advertising a Sanwa speed control, do they own Sanwa?
#7415
MiCk B. :-)
#7416
They last longer for one. Plus the design is better imo. With stock AE cvd the ball joint is on the cvd dog bone side so it is exposed alot more allowing dirt to get in which causes wear. Look at the MIP design where the ball joint is on the axle side which helps keep the dirt out. Plus the holding ring design is much better then the snap ring.
#7417
#7419
#7420
Servo question...
i've built 4 associated cars since last august. What is the proper way to set the servo arm? THe manuals say to offset the servo arm 5-10, approximately 1 spline over and there should be a 2mm gap between the ball cups. Once you've done the servo link and offset the arm, the steering rack usually isn't perfectly straight, so do you use the sub trim to align the steering rack while the link is hooked up or take off the horn, adjust the sub trip, then replace the horn?
I've been setting mine with the servo arm straight up and adjusting the servo link to fit since this usually works so that i don't have to use any sub trim to align the rack. I think i could be losing steering radius by doing it this way.
#7422
Servo question...
off set the servo horn , makes for equal Max steering Left & Right...
#7424
#7425
yeah, some radios have more subtrim movement than others. My airtronics takes like left 60 to get it right. It only goes to 100, so if I and off too much with the install of the rack, then I cant get it to center. But if that is the case, my install was probably wrong anyway. The way I understand it is. Sub trims adjust your epa to match the subtrim changes, but the trim shifts left and right, but does not touch the epa, thus messing it up. I have adjusted sub trims and noticed that my epa seems to stay correct, so i never use trims.
4Likes
