Team Associated B4.2 Thread
#6977
#6980
Believe the shelf lets the car feel more connected .
Car is more reactive and agile.
Steering becomes even or same in both directions ..
Using a shorty with the 40 gr ballast offers awesome balance as you found and the grip is just great ..
Did a test run last night with my Vision-Racing steering rack .
Mounted the stud in the most forward location . The steering is smoother this way then stock and looking forward to tonight's club race .
#6981
Sorry, brand new to buggies, so trying to absorb the hive knowledge.
#6982
#6983
WC, have you tried running it in the batt. tray? I tried the shelf once but it made the car feel a bit lazy sort of took the twitch out of it. Maybe the shelf with a combination of other changes would have felt better but I only did the shelf by itself and then quickly removed it.
I run it in the tray now and it feels money. But I did make a combination of changes after putting the esc in the tray. Wondering if the shelf feels similiar or not.
#6984
#6985
chevmaro
have a team mate running all down low & centered & drives his all the time .
Don't agree with your assessment however , the shelf makes the car roll more , this helps the feel & responsiveness...
Down low is smoother less roll but feels more numb , not as reactive but smoother in the corner steering...
Both perform great , side with the down low & centered on very high traction conditions.
Side with using the shelf on normal or med traction, shelf allows any size pack to fit so you can use either battery size...
#6986
I have been taking my car out of town with me when I travel for work. I hit up the local tracks and it drives just as well as on my home track. I change hubs, shock oil, tires but nothing major. I really like this car.
I really want to try a set of the avid 2+2 pistons next.
#6987
#6988
Ok, I tried to find this info but after reading 100+ pages my eyes hurt, so I am going to ask away. What servo would you guys recommend for the B4.2? I would also like to use the same servo in my T4.2 - never gone without a servo saver before and I want to make sure I get something that will last. I have been looking at the Futaba S9452, the XP servos (don't they have a plastic gear??), the Airtronics 94770 & 94774, and the Spektrum S6030 & S6040. Would any of those work well in the B4.2/T4.2??
#6989
#6990
Yeah, Im partial to Futaba - had a Futaba servo in every 1/10 car I have ever owned, going back to my gold pan RC10. I currently have the S5030 digital metal-gear servo in my FT T4.1. It has been through some hard landings and crashes and still works like new after two years of consistent use. It's rated at 90oz-in at 6 volts, so I thought I would need something more robust to use without a servo saver. I was looking very closely at the S9452, it's rated at 128oz-in at 6 volts - is that enough torque? It also has a coreless motor, ball bearings and metal gears.
4Likes
