Tekno SCT410 Thread
Can anyone tell me if they have ran the Hobbywing esc with the Revtech 4800 motor?
Is the esc sensored?
I too am a Tekin guy,but don't mind trying something new.
I just blew through another Rx8,and have 5 more in other vehicles,but I also believe that their behind the ball when it comes to 4 poles motors on 2s....
Thanks in advance.
Tekno FTW!
Thanks in advance.
Tekno FTW!
Thanks in advance.
Tekno FTW!
Thanks in advance.
Tekno FTW!
The control, smoothness, feel has been the same as the RX8. It's much easier to adjust the settings. I really like the on/off switch. I've had to hard wire my RS so it may get a HW switch.
[QUOTE=RokleM;12233669]Depends on the ESC. I would probably recommend the SCT-PRO (120a) which can run either sensored or sensorless. To be honest, I've been running tests, and smoothness wise I can't see much if any of a difference.
Ty,
I'm gonna purchase the Blue Hobbywing 120amp.....Just wanted to be sure that my Revtech wouldn't punish another ESC...
I've heard nothing but good things about these Hobbywing combos.I hope it holds true..
Ty,
I have also owned a couple tekin rx8s but I sold them both after using the HW escs. The warranty on the HW is 6 months if you purchase from HWNA vs 90 days from tekin. I can also email a HW tech 24 /7 (including the weekends) and I'll typically get a quick response to my question or issue.
maybe someone can help me here,i have a rx8 with a tekin sc 4 pole 4.5 turn and i find my batteries are a bit puffed and hot after i run. i am a bit electronically challenged
and was wondering how i should set this up with the link. if someone could suggest some settings i would be very grateful. i am running a 16th pinion and 6300 40c track and field batteries..thanks
and was wondering how i should set this up with the link. if someone could suggest some settings i would be very grateful. i am running a 16th pinion and 6300 40c track and field batteries..thanksAt this point I would still suggest a HW over a Tekin but that is only my personal experience.
and was wondering how i should set this up with the link. if someone could suggest some settings i would be very grateful. i am running a 16th pinion and 6300 40c track and field batteries..thanksWhat motor are you using? I'm still troubleshooting at this point. I couldn't recreate the stutter and it may only do it once during a run and not for long enough to matter at all. I tried a new sensor wire so my options are either motor or software and it only started doing it after the firmware change so that's the next step.
[Drag Brake Force]
0%(*)(+)
[Low Voltage Cut-Off]
3.4V/Cell(+)
["DDRS" Start Mode]
Level V(*)(+)
[Maximum Brake Force]
75%(*)
[Initial Brake Force]
=Drag Brake Force(*)(+) 0%
[Neutral Range]
6%(Narrow)(+)
["AMTS" Timing]
15.00(*)
i dont know man. hit it with a pitchfork and watch it burn, or run over it with a lawn mower..........but seriously idk. might not be any coming back from that
Once they puff u can't unpuff them.. These 4x4SC's and 4 pole motors put a hurtin on a 2s lipo. +1 on the higher c rating and be sure to keep them balanced. A quality 2s lipo is key to a good 4x4SC setup.
Another thing to consider is depending on what your doing w/your truck, a 2 pole 550 may be a better choice for u. I've been running tekin's 4000 and 4600pro4 indoor/outdoor since they came out but for a few weeks I've been running a Reedy Sonic 4t outdoor thats smoother bottom end but just as much snot up top and my lipo's love it.
17Likes
