Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 05-16-2013 | 04:05 PM
  #10141
8 x 1.3 shock pistons not only fixed it for me, now I need brake in the air!
photopro is offline
  #10142
Bernard_Jr's Avatar
Originally Posted by Rockthecatbox21
So is current limiter the answer here, or punch control? Why would you limit overall power versus just limiting how strong it comes on? My hobbywing 4000Kv seems to have just enough power for my tastes, but i really don't see how current limiter would help my driving, versus punch control limiting my wheelspin. I also noticed my truck keeps shutting off at weird times during the race. I tried a new sensor wire, re-did all my solder joints, checked to be sure all my bullets were tight fitting, and made sure my receiver plugs were fitting right. It will just have no throttle for 10 seconds, but the steering works fine. I'm using good new smc race formula packs as well. I don't know what else to do.
That does sound funny. If the steering quit too I'd say a glitch buster but that sounds like an internal esc issue to me. Does it happen closer to the end of a run or just random? Maybe the switch acting up and the delay for the receiver/servo is just small enough not to notice as compared to the esc.
What esc are you using? Are you running an external BEC?
I'd say current limit for temps and punch control for handling.
Bernard_Jr is offline
Old 05-16-2013 | 04:06 PM
  #10143
I changed all 4 and no more nose diving.
photopro is offline
Old 05-16-2013 | 04:21 PM
  #10144
Originally Posted by Eaglesrx
hey cain, is your shock setup for loose outdoors?
thanks
He doesnt know anything. ...
Raul Garcia is offline
Old 05-16-2013 | 04:26 PM
  #10145
BashemSmashem's Avatar
I went to pink and green springs and upped the oils by about 10wt per side , made a big difference in mine . Wanted to get the 8x1.3 pistons but they sold out rather quickly after the sale at amain started ......
BashemSmashem is offline
Old 05-16-2013 | 04:40 PM
  #10146
advpball's Avatar
I glued 2 holes on rear pistons shut and helped nose diving a lot!!
Can't wait for outside track to open
advpball is offline
Old 05-16-2013 | 04:43 PM
  #10147
CentralCoaster's Avatar
Originally Posted by snwchris
Back when the SCTE came out, yea people were shaving weight like crazy, cause only option for motors were 2pole and were getting hot. With the 4poles now adays it doesn't seem to be the huge concern it once was.
Originally Posted by BashemSmashem
I agree , batteries have come a long way as well .
Awesome. So then let's throw a 4pole 550 can on there and start all over again.
CentralCoaster is offline
Old 05-16-2013 | 04:46 PM
  #10148
If you don't mind, what springs and oil did you go with after the closing of the piston holes?
teknorookie is offline
Old 05-16-2013 | 04:49 PM
  #10149
Rockthecatbox21's Avatar
It's a mamba max pro with the castle 10 amp external bec, paired with a hobbywing 4000Kv motor. It happens at random times, happened at start of a race, middle of a race, and towards the end of a run, so there's not really a pattern here. I disabled the switch, so it's not like it's ever "turned off", just loss of throttle. For now, i'm gonna try my other "backup" mmp and see if that fixes it.
Rockthecatbox21 is offline
Old 05-16-2013 | 05:11 PM
  #10150
justpoet's Avatar
I had similar issues with my MMP about a month and a half ago.
We sent it in and it was replaced. The replacement worked ok, but without current limit it would still cut out just from motor draw (HobbyWing 4700kv).
justpoet is offline
Old 05-16-2013 | 05:12 PM
  #10151
Bernard_Jr's Avatar
yeah that means you'll never lose steering. sounds like you've checked just about everything. Anything hot when you're done running?
If you remove the switch from the equation it sounds like a bad cell causing the lvc to kit it. If the battery isn't the case, sounds like it is time to try the other esc.
Old 05-16-2013 | 05:22 PM
  #10152
timamybrown's Avatar
I had a problem like that with a mmp when I had the car on the stand and giving it throttle it would spins the tires then stop with my finger still on the throttle. I had to keep changing the firmware until I found something that worked. I always had problems running any type of beta firmware with a 4pole motor for some reason.
timamybrown is offline
Old 05-16-2013 | 05:23 PM
  #10153
advpball's Avatar
I used asc 30wt and green springs. the jump had short run up and 3ft straight up type table top.
advpball is offline
Old 05-16-2013 | 05:26 PM
  #10154
I'm running the 4000Kv version, so i have a little less power. Still, i've never had to use current limit with my old tenshock motor, and i know that thing drew just as many or more amps than the 4700Kv hobbywing. I'm in the process of putting in my backup mmp esc and will see if that fixes it.
Like i said, my smc's are only a few weeks old, and both cells are @ the same voltage, so i don't think it's the batteries. My setup never ran hot, highest temp i saw was around 150°.
Esc wasn't even warm.
Old 05-16-2013 | 05:31 PM
  #10155
Bernard_Jr's Avatar
there was some MMP stuff several pages back that may have talked about the firmware. I skipped past it as the poster suggested.
