Tekno SCT410 Thread
Quite possible, I replaced TKRBB10154 with the stub axles. I am just hoping that I dont start snapping stub axles. We will see
They are heavy enough to benefit from it and do run smoother. 1/8 buggy wheels do as well. 1/10 buggy tires, I just balance them because I can
Ideally you should balance any tire that get power. When they are spinning the tires create a lot of force and multiply any off weight.
Your right i just dont see many guys i race with that run 4x4 SC balance them . If it was a race that was pretty big i may see it .
What if I have 3 or 4 through them and it's still doing it? Take the balancing clay off and run a few packs without it and see what it does?
You could. You may just need to re-balance them.
Back Order
I have been looking for this truck everywhere, with no luck. Are they releasing a updated version?
Is 6500mAh enough for a ten minute main?
Tech Legend
That will depend on your track, power plant, and driving style. If you are trying to get high mah on the cheap, I have seen GPR 7200mah lipos from the barn floor for like $55 each, if I am recallying correctly.
Question for everyone, how viable to do you feel the SCT410 platform is in 1/8 E buggy usage? been toying again with using an SCT410 platform as my E buggy and then cutting down on spare count I have in the box.
+1 if talking about the SMC's the cost and weight difference is small enough to make it worth it. If you already have the 6500, you can try it out at a club race and see how it works for your track and driving style before deciding if you need to go bigger.
