Like Tree248Likes
Xray XB4 thread
Old 07-25-2017, 03:44 AM
  #12451
frankf's Avatar
Get the bezerk slipper eliminator i believe it uses Kimbrough spur gears so you can use a 69t
frankf is offline
Old 07-25-2017, 04:08 AM
  #12452
bd581's Avatar
Originally Posted by marco cianfrone
Hi guys I would like to race the car in 17.5T stock, but the smaller spur gear is just 75 tooth. Can I get anything in any other brand smaller than 75 that fit the xray slipper clutch? Maybe 72 tooth.
You can fit up to a 33T pinion with the 75T spur.
Common modification is to run a 69T associated spur and pads with the spur drilled out a bit to fit. However I'm not sure if you can do that with the 3 pad slipper setup of the '16 and '17 cars (I'd like to know)
Other choice is to run the Bezerk slipper eliminator.
bd581 is offline
Old 07-30-2017, 09:16 PM
  #12453
Trader Rating: 43 (100%+)
so what's a good setup for carpet 13.5T ?
Phillip F is offline
Old 08-02-2017, 05:20 AM
  #12454
Default First dip Into the xray world ..... HELP
Coming over from the dark side (AE TLR) I just purchased a clean 2015xb4.
So I know I could read all 881pages to possibly find the answers but I thought I would throw it out there.
TURF medium/small track 15sec laps. Island and cruzin
13.5. But occasionally 10.5 motors
What if any changes must be made. It has 12mm.
What parts are interchangeable between model years
What is a good turf setup starting point.
Thank you all
Oldbutlearning is offline
Old 08-05-2017, 09:52 AM
  #12455
Been out of the loop for a while when will we see the 2018 xb4 ?
evolution03 is offline
Old 08-05-2017, 11:37 PM
  #12456
Blue 31's Avatar
What are people doing to get the weight down on the 2017 for stock? Currently weighing in at 1700g pretty much stock.
Blue 31 is offline
Old 08-06-2017, 09:42 AM
  #12457
18 may be out in december, I think thats when the 17 came out.
racingnewb is offline
Old 08-06-2017, 07:21 PM
  #12458
Pville Stig's Avatar
Are you running 13.5 or 17.5? If so, composite gears in the front and rear diffs is a good place to reduce weight. The ring and pinion gears. Also a slipper eliminator is another good tuning item.
Pville Stig is offline
Old 08-07-2017, 02:53 AM
  #12459
Blue 31's Avatar
Running 17.5. Have a slipper eliminator just waiting for the spur gears to arrive before setting it up. I will have a look at the composite gears. Thanks.
Blue 31 is offline
Old 08-07-2017, 11:39 PM
  #12460
what tires and inserts are you guys using for a carpet track?
Old 08-08-2017, 06:05 AM
  #12461
mourinho's Avatar
Trader Rating: 46 (100%+)
Proline Pin Point rears in Z4 compound, Proline Wedge 4wd fronts in Z3
mourinho is offline
Old 08-08-2017, 08:05 AM
  #12462
snwchris's Avatar
If I remember correctly I don't think that the 17 was released until February or March of 2017, but usually in December they start posting pics or teasers of it.
I bought my 16 XB6 at the end of November 2016 cause I didn't want to wait for the 17 model and was more interested in the 16
snwchris is offline
Old 08-08-2017, 08:18 AM
  #12463
rraden's Avatar
Trader Rating: 259 (100%+)
I can't imagine what changes they would make to it. The only thing I could see is moving the rear inner hinge pins inboard just like they did on the 17 XB2 Dirt Edition.
rraden is offline
Old 08-08-2017, 09:36 AM
  #12464
Why does no one make a body for this buggy?
Sean B. is offline
Old 08-08-2017, 10:26 AM
  #12465
HollywoodRC's Avatar
I am running Pro-line Wedges in the front and Pro-line Pin Points in the rear. Z3 compound all around. They have stupid traction.
HollywoodRC is offline
