Like Tree248Likes
Xray XB4 thread
Old 11-30-2015, 05:30 PM
  #9511
kuruption's Avatar
Trader Rating: 24 (100%+)
Hard to tell from the video, but your car looks to be pushing going into the corner. Is that the case?
kuruption is offline
Old 11-30-2015, 05:32 PM
  #9512
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by raved007
I have this video as you can see in a curve area section.
https://www.youtube.com/watch?v=0idR1FsxFqY
If I were you and we're looking for more steering the first thing I'd do is shorten the rear camber link if you haven't done that already. If that's not enough I'd narrow the front track width moving the dot inward. and move the hinge pins to the bottom position. The +1 inside bottom corner for max front end grip. If that's not enough move the rear hinge pin up, this will keep the rear flatter and give you more steering also...
symmetricon is offline
Old 11-30-2015, 05:45 PM
  #9513
Trader Rating: 36 (100%+)
Thanks i will do that and i'll give a feedback.
raved007 is offline
Old 11-30-2015, 05:49 PM
  #9514
That's right i need to slower in curve are section.
raved007 is offline
Old 12-02-2015, 06:47 AM
  #9515
Slapjack's Avatar
Trader Rating: 19 (100%+)
What is the internal drive ratio of the 2014 XB4? I am trying to figure out FDR.
Also how do I determine what the FDR should be for different turn motors? My 17.5 Trinity came with a manual that says for 1/10 buggy to be between 5.5-6.5 but I also have a 8.5T and 6.5T tekin and LRP and not sure what the FDR should be for those.
Slapjack is offline
Old 12-02-2015, 07:32 AM
  #9516
BentKa's Avatar
On the Xray site you will find all the specifications for each model under "Specs".
For the XB4 you can find it here (specs for gearing have been the same since 2013):
http://www.teamxray.com/xb4/2016/specs/
Bent
BentKa is offline
Old 12-03-2015, 08:31 AM
  #9517
Slapjack's Avatar
Bent
So 1:2.5... does that mean when I calculate the FDR I do (spur/pinion) x2.5=FDR?
Slapjack is offline
Old 12-03-2015, 09:13 AM
  #9518
Trader Rating: 118 (100%+)
Yes
Chris Furman is offline
Old 12-03-2015, 09:50 AM
  #9519
gticlay's Avatar
Trader Rating: 14 (100%+)
Yes, we had a little discussion about the car and 13.5 motors a short while back. http://www.rctech.net/forum/14262709-post9310.html
gticlay is offline
Old 12-05-2015, 12:05 AM
  #9520
Has anyone run a XB4 '16 as a 2wd on carpet? Experiences?
AntH3000 is online now
Old 12-05-2015, 08:44 AM
  #9521
1evo RRR Driver's Avatar
Fellas quick question.......im new to xb4. I purchased a 15' n wanted to know if it's possible to use a few of the updated parts from the16' mostly interested in the stronger front diff case n front arms! If its possible will i need to also use the 16' front tower?? Thanks
1evo RRR Driver is offline
Old 12-05-2015, 10:10 AM
  #9522
Yes the cases will work but yes you will either need to get a '16 front shock tower or do some dremeling to the '15 tower.
Also, the '16 tower geometry is a little different.
punkracer24 is offline
Old 12-05-2015, 10:44 AM
  #9523
Thanks......
Old 12-07-2015, 05:23 PM
  #9524
Spork's Avatar
Questions??
I recently completed the build on a 2016, and plan to run 13.5. However, with the stock spur, the largest pinion I can fit is a 26. I'd like to try a 29. Any idea what I might be doing wrong, or did wrong in the build?
Spork is offline
  #9525
kuruption's Avatar
Xray sells smaller spur gears that should help you out...
