Xray XB4 thread
#8026
IF it is the front you have trouble with something like this will help you:
http://www.warny.pt/store/xray-xb4-b...ny?search=Xray
We run it and haven't broken a front diff housing since we started using it.
/G.
/G.
#8027
Do you know when the stiffer side pods and CF chassis brace stiffeners are going to be released? I like the idea of being able to switch things up quickly. Thus stiffer side pods and CF stiffeners for the chassis braces will nice option parts to have and quick to swap in and out.
as always your input and advice is greatly appreciate.
#8028
Makes you put in some more effort when accessing the diff, but trust me, it works and is well worth it.
/G
#8029
We have had the exact same breakage, and the brace does help. What it does is that it connects the four shock tower bolts with the top two bolts of the diff case lid.
/G
/G
Thanks for the link to this part. I can definetly see how it strengthens the front diff. Looks like one could install one of these on the rear as well.
I will be ordering 2 of these. If one has the roll center brace it looks like one would you have to remove part of the backside (backside of brace that connects to the diff case) or is the backside/mounting side of this part flush? This brace used in tandem with the roll center brace(lower steel shock tower plate) woul really strengthen up the front.
Thanks again my friend
#8031
I've been running something similar from Ralls Racing for the last 2 years, not had one breakage since, the first bulkhead lasted 3 meetings before I got the brace.
#8032
https://www.google.com/url?sa=t&sour...BTVbkbyMRXpIlg
#8033
i have a sim brace on the front,it allows you to connect the lower part of shock tower to the top to support it,the way mine is breaking in the rear,there is no place for the support to bolt to help,i dont see any other way to make it stronger than have it made of billet?
#8034
With an aluminum bulkhead I would imagine you would just snap towers instead. Something has to give.
#8036
Greger,
For the rear it won't work, unless maybe if you run the shock tower in the rear position.
/Greger
#8037
Still in the process of building my car. I went ahead and got the center diff for it. Im gonna be running on a outdoor medium bite track. What center oil should i start with. I know when I had the 44.3 on a indoor medium bite track I tried 100k and it was to aggressive. So went back to 60k and liked it better
#8038
The back side is not flush, so it is adapted for stock geometry without the roll center brace. I find that with the new towers there is very little or no need for the roll center brace, so it will do its job without it.
/Greger
/Greger
#8039
Thanks for the additional brace info. my friend.
#8040
i race on a medium size low bite track and started with 100k in the centre out of curiosity i went down to 20,000
and loved it i had heaps more off power steering and on power the 15 was a lot better.3 other drivers with their xb4s dropped their centre diff wt that day and all of them
preferred it .
here is a quick vid of my 15 running 6/20,000/3 at the track i qualified 2nd and hit the lead at the first corner
white/black paint job
https://www.youtube.com/watch?v=wXhnetk-EMI
