Xray XB4 thread
#4411
#4415
#4416
My rear diff is clicking after 1 race day. It doesn't feel loose like it needs a shim so should I loosen the slipper a little more or shim it super tight.
#4417
I have not found the need to shim my diffs - Xray tolerances are very good.
1) Pull your diff.
2) Inspect the pinion gear - the one on the center shaft. Be prepared to replace it.
3) Check the ring gear on the diff.
4) Open your diff up and examine the gears. Check the spider gears for chipped teeth.
It's gotta be somewhere!
#4418
Chances are your slipper was already too tight and you've chipped a tooth.
1) Pull your diff.
1) Pull your diff.
#4419
R/C Tech Elite Member
http://www.teamxray.com/teamxray/new...ec1c57083258be
#4423
What avid pistons are you guys running
#4424
