Xray XB4 thread
#2821
http://www.teamxray.com/teamxray/news/news_main.php
They are always extremely active, everywhere.
I can understand that they don't want to go to this worlds. They have been in 1/10 off-road for less than a year.
#2825
I also installed Durango CVD dust boots on all CVD joints - so now the pins are well covered, kept clean & well lubricated using Tamiya Anti-Cease grease.
Next up - Avid pistons & maybe some Ralls Racing Shock Towers.
Side note - Hey Avid, please make some machined 2-hole 1.6 & 1.7 pistons like what Martin Bayer used for his Euro Championship win!
#2826
#2828
#2829
Question:
I was just playing around and swapped out the plastic for the metal gears and to me it just doesn't feel as smooth.
Do you have to run a little lighter diff fluid when you switch over to the NT-1 metal gears? What do you do differently when you build the gear diff with the NT-1 gears. I know you can't use the scale to weigh your diffs anymore. Do you still fill it to just above the sat gears? The NT-1 sat gears look larger than the stock plastic gears, so I'm guessing you would need a different fill line for the metal gears due to the larger diameter? Or maybe my eye site is going and I'm just seeing things. I may just put the plastic gears back in, I haven't had a problem with the stockers.
I don't know maybe it's just my imagination....
The car is great....!!!!
#2830
i noticed the same thing and went back to the 1.3 - 3hole to compare. a definite lack of pack with the 1.7. So either be sure to downside the jumps very well or try a smaller hole. the 1.7 should be very helpful on a bumpy track with smooth landings though.
#2831
Just picked my XB4 can anyone suggest some extra spare parts I should order to have....no one local or any of my tracks carry anything for these. Club racer I usually run at least twice a week. Thanks
#2832
Question:
I asked the same question about a month ago if there was an exact way of filling the diff and the best solution I learned is to scrap the scale and eyeball it. just fill above the sat gears. I have the stock plastic up front and the nt-1 in the rear. just make sure you have spare time to let the fluid settle before sealing it up
#2833
363350 composite upright rear
364960 Gear diff outdrive adapter V2 (one set should be fine)
The stock wing is very fragile, so I recommend you find some 3rd party wing.
I have tried the JConcepts xb4 wing and it is quite good, but I have been told that the LMR Electra wing is even better.
http://l-m-racing.co.uk/products/ind...&product_id=53
I also picked up a screw set from Tony's Screws, but if you don't loose them like me, it should not be needed.
If you are completely paranoid you could maybe add towers and arms for when the Big Crash(TM) happens, but I don't think that should be needed for normal racing.
#2834
I made a purchase today.
