Xray XB4 thread
#2282
Cheers, I've got small sheet of 2mm carbon here, so I'm going to fab some battery straps as well
#2287
Use your imagination
#2290
They are Ballistic Buggy Spikes in green (soft) compound, it's what we run in the wet on astro in the UK
#2291
#2292
countersunk
hi,
if anyone using Hudy alu countersunk shim, tell me what thickness it have.
If u use it for top deck did you use Flat Head 3x10 screws to add 2mm for shim thickness?
#2293
There is this one... http://www.rctech.net/forum/electric...gy-rumors.html
#2294
A liitle vid of my XB4 in action at a practice session at my clubs track yesterday afternoon
http://www.youtube.com/watch?v=GiL25EJc2ak&sns=em
Sorry about the quality
#2295
XRAY racers can now run the signature AVID machined piston setup on the XB4 buggy. The AV1033 pistons are custom machined for XB4 shocks to tune high speed and low speed damping separately with 2 large 1.5mm (or 1.6mm) holes and 2 small 1.1mm holes (we call it the 2+2 piston). AVID’s test drivers found that these pistons help provide the traction and bump handling of running lighter shock oil or larger piston holes, while still maintaining the control of running heavier oil or smaller hole piston when taking on jumps.
Piston Features:
* Fits XRAY XB4 shocks
* Machined perfectly round with a tighter fit to bore of shock body for less blow-by
AV1031 pistons with 2+2 valving offer increased traction without sacrificing jump handling or driveability.
* Each package includes 4 pistons inside of a Doodad container printed with AVID logo.
Piston Features:
