STRC Slash 4x4 LCG chassis coming soon
#241
Tech Legend
Trader Rating: 51 (100%+)
Received my chassis and took a picture of the items going in the truck. Also I haven't seen where the Jack Link's is used in the construction of the truck, but I have mine!
Haven't reached my post limit yet so you will have to copy and paste the link. This was taken with my phone, I will provide better images as the truck is built.
i1289.photobucket.com/albums/b508/MidTCrawler/Traxxas_Slash_4x4_STRC_LCG_002.jpg
Kevin
Kevin
#242
quote wyd
Last night I really did get to play around with the motor mount. I didn't have long enough motor screws in so my motor was coming loose which was totally my fault. Nice thing though is I changed pinions 2 times last night and then used longer motor screws to mount the track part of the aluminum mount to my motor. Then sliding it into place and getting proper gear mesh was a breeze. Could of been easier!!!!!!!!!!! Just use the right sized screws for the motor. [/QUOTE]
Running same motor. So WHAT are the right sized screws so I don't have the
same problem?
same problem?
#243
very soon
I had my truck at the track today and it was a mess. I tried some new springs and I couldn't turn consistet laps. I'm used to 2WD SC and Buggy so the 4x4 world is still foreign to me. Not knowing how to drive a 4x4 plus a bad setup equals a rough day. Today's track experience gave me another reason to buy this chassis.
There was one guy running the RCE chassis on his Slash 4x4 and he was doing much better than me. Funny enough, last night I read through the RC Short Course forum thread about the STRC chassis ... whoa, what a mess that turned into. Glad to see it was resolved (kind of).
I will keep checking this thread for customer updates and hopefully indoor clay set-up ideas.
#244
Kevin
Kevin
Have fun as it looks like a ton of good stuff there.
#246
Optional "tools".
Going to get started on it tomorrow as I want to take some pictures while I'm doing it.
#247
Help
Just finished putting together my LCG kit and its amazing!!! so far
1 problem..I'm using all the traxxas stock parts , and now that you put the servo in side ways. How do you adjust it to work?
Thanks!!!
other quick notes, the battery post/clips, they just don't fit right, it will not line up unless you cut that small tip off the bottom, cause where the screw is suppose to screw into, the tip goes instead, so i cut it and rotated.
also the batterys with quick pull out, will bend like my gen aces. ;
Thanks!!!
#248
yeah, rc short course is a bit harsh....
#249
Thanks!!!
Thanks!!!
Ideally you'll want to be able to adjust the end points as well to make sure the servo doesn't throw too far left and right.
Steve
#250
Tech Legend
#251
Tech Legend
Putting on a LCG chassis from STRC I gained over a 1 second a lap faster with not even a good setup. Tonight I will work on getting my chassis setup on and hope to get some pics with at least the roller setup. Electronics normally take me awhile as I really like a neat setup and that takes me a lot more time to do overall.
Its is a little bumpy on the other site but often times great products take some lumps because others are jealous. It happens to all companies at one time or another. Can't do much about others posting false info. Happens daily to all business's.
#252
I've never been to any other forums before URC... and the only reason I am on here making a post at all is because Steve linked this one at the bottom of his site... (why he hasn't linked the thread at URC I don't get.)
I'm not trying to put down any other forums at all here... but I just don't get why folks don't think that the golden rule should still apply...
The Golden Rule: for those who have forgot it:
"If you don't have anything nice to say; shut your damn mouth" (I'm paraphrasing.)
#253
I follow 4 forums right now.
That is down from 7 ,lol.
Traxxas, Ultimate RC, RC Short Course and R/C Tech.
A ton of good information in all the forums.
#254
Tech Legend
#255
Any ideas
I put my kit together today, it went fairly smooth until I tried to set the mesh. I think I have the mesh set about as good as it'll get and it's very noisy. The pinion and the spur are both new. Any body got any hot tips I would sure apprecite it. I not a rookie, I've doing this for a long time and this is bugging the heck out me. Oh by the way the kit brought new life back in my intrest of my old Slash. I'm looking forward to hitting the track with it in the next few days to see if it can keep up with my SCTE or my SC10 4x4. I was comparing the way they sit and I think the old girl is going do just fine. I had a bunch of motor esc options. I decided to run a cc 3800 with a mmp to keep the weight down and steering will be handled by a Savox 1256. Nothing fancy but should roll pretty good. I'm curious about the weight so I'm taking it to the grocery store tomorrow morning to weigh it. You did a good job Steve, this is going to be a big seller!
I must have been over tired, I reset the mesh today and it's much quieter. All I have left to do is shorten the motor wires and tidy the wiring a bit. Oh and take the Losi stickers off that body. LOL
