The AE FActory Team B44.2 Thread >
Old 10-27-2013 | 08:47 PM
  #6046
Wild Cherry's Avatar
Tech Legend
Originally Posted by yunowill
When you guys think the next 4wd buggy be released ?
Personally don't believe it will be a new car , rather a new alloy chassis made the same length as the 44.1 chassis...
Wild Cherry is offline
Old 10-27-2013 | 10:40 PM
  #6047
mharlow's Avatar
Originally Posted by TJMac
Yeah I'm familiar with the BB/Durango conversion, that wasn't what I asked. I know AE was running gears at Worlds...I want to know who's gears they were.
AE were running the Durango diff with the bugle boy conversion. You need both to make it work.
mharlow is offline
Old 10-28-2013 | 09:39 AM
  #6048
Waflet's Avatar
Originally Posted by t0p_sh0tta
Nothing he mentioned is adjustable via the radio.
Hideeho
The brake strength is adjustable on virtually all digital radios. Throttle low EPA or brake EPA will do it. The throttle speed is adjustable on the 4pls, 4pks, 4pks-r, mt-4, m11x, & m12 (& I assume others). I run a dx3r pro (EPA adjustments, but no speed adjustment on just the throttle side the way the Futaba & Airtronics do it) so I only adjust my brake EPA from the transmitter. I set the brake (& reverse seperately, when used) strength slightly higher than I typically want it for actuall use in the car (75%-90%) & then back off the EPA on the transmitter to fine tune the brake strength on the track. I check & adjust as necesary before each heat. There are times I would like to adjust this during the race, but the dx3r pro can only bind the throttle high to a switch, not the throttle low.
Waflet is offline
Old 10-28-2013 | 09:49 AM
  #6049
tibbs's Avatar
Anybody doing the diff conversion besides bugleboy? I know he is waiting on parts I'm just wondering?
tibbs is offline
Old 10-28-2013 | 10:06 AM
  #6050
t0p_sh0tta's Avatar
Nope.
t0p_sh0tta is offline
Old 10-28-2013 | 10:30 AM
  #6051
gticlay's Avatar
I have finally dialed in my B44.2 to a point where I am enjoying the car on the track. Took me a few races and I learned something: When your car starts getting snap steer off throttle, it may not be your driving style or setup. It just might be that your transmission housing has cracked at the bottom and you have excessive chassis flex causing said off throttle snap steering. Of course once that's fixed BBbrrrrraaappp!
gticlay is offline
Old 10-28-2013 | 10:32 AM
  #6052
Tech Legend
GtiClay
Gave it the eye , lookN good....
Old 10-28-2013 | 11:50 AM
  #6053
gticlay's Avatar
Originally Posted by Wild Cherry
GtiClay
Thanks Mr. Cherry.
gticlay is offline
Old 10-28-2013 | 01:50 PM
  #6054
rcgod's Avatar
I sent him the parts and he machined them because he didn't have any in stock and everyone was out. Mailed them 2 weeks ago and got an email yesterday that they should be done today. He knocked $35 off the cost since I furnished the parts. Probably the quickest way to get it done until he can get some gears in stock.
rcgod is offline
Old 10-29-2013 | 09:28 AM
  #6055
+1 Had the same situation go on far too long.
34x17 is offline
Old 10-29-2013 | 05:09 PM
  #6056
I have been talking with him aswell and he also told me that he wont have any kits until he can get parts. Its funny that you mentioned that you sent him parts to machine. Because I was thinking the same thing.
So you just sent him the 2 DEX410 pinions and the 2 B44 shafts ?
yunowill is offline
Old 10-30-2013 | 05:05 AM
  #6057
rcgod's Avatar
Yes. Nice guy to deal with. Just give him a heads up that you're sending the parts.
rcgod is offline
Old 10-30-2013 | 07:10 AM
  #6058
Originally Posted by JsK
The Fuse ESC works fine in a wheeler, they are actually a lot smoother
than most people think. Make sure you set the Start Power, Throttle
Speed and timming back to there lowest settings. Also you will NEED a
fan. Either the Castle or Dynamite motor will work I just prefer the 3800.
It will also need to be geared up several teeth beyond the normal 6.5-8.5
gearing.
Here are my ESC settings
1.Brake Strength-3 (I would run this as low as possible to keep strain off the
diff gears)
2.Drag Brake-1= 0%
3.Throttle Speed-1= Very Soft
4.Start Power-1= Very Soft
5.Reverse Power-1= 0%
6.Run Mode-1= Forward Only
7.Motor Timing-2 =soft
8. Battery-4= light lipo discharge
Any suggestions on gearing with the standard spur? Not sure what 4 pole 3300kv equates to in turns.
scothershman is offline
Old 10-30-2013 | 07:53 AM
  #6059
t0p_sh0tta's Avatar
3300kV is 13.5-ish
Old 10-30-2013 | 07:55 AM
  #6060
godofcable's Avatar
3300kV is 13.5-ish
+1
godofcable is offline
