Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-05-2015, 02:03 PM
  #11431
Originally Posted by phillypete
For those of you who have dabbled in the black magic that is Zach Roger's OCRC setup:
What would you do to gain a bit more rear side bite?
... and I've already been through the tire and sauce gauntlet to get everything I can out of that department.
try lower a rear roll center.....or maybe a bit longer rear link.
Jason Snyder is offline
Old 01-05-2015, 11:38 PM
  #11432
Originally Posted by K_King
You can remove the screws from the waterfall to get more grip, it's a quick adjustment that you can definitely tell.
cheers
RichD is offline
Old 01-06-2015, 07:24 AM
  #11433
tonyv2382's Avatar
Trader Rating: 67 (100%+)
So Ive messaged quite a few painters with no reaponse on here. I need a painter asap with good turnover time and skill. USA only please if anyone has any info please inbox me some details and examples if possible. My painter retired.
tonyv2382 is offline
Old 01-06-2015, 09:57 AM
  #11434
Trader Rating: 75 (100%+)
What are you all using in between the motor and shorty when you are pushing the shorty all the way back. Gonna put ZR setup on my car.
Also the car im using came with the avid topshaft and slipper system. However it came with 76 or 78 spur cant remember. When I was looking online it says these are for stock. Can I not use this with a 7.5? If im able to use it whats the pinion range.
gixxer420 is offline
Old 01-06-2015, 11:35 AM
  #11435
Cut a battery foam like a 1/4" all the way across width wise, should be about right.
76 is what most guys use for mod(spur that comes with the car new) at the surf city stock guys were in the 69-70 tooth range on the spur with 33- 34 pinion.
CaseyD is offline
Old 01-06-2015, 11:45 AM
  #11436
Good deal thx CaseyD
Old 01-06-2015, 12:44 PM
  #11437
I am using the battery stop from the RT6. It screws in under the motor.
phillypete is offline
Old 01-06-2015, 12:58 PM
  #11438
Trader Rating: 25 (100%+)
Two battery pads from my B4. The normal sized ones not the little thin ones. It's a tight fit at first, just jam it in there. After running it this way for a few days the pads will conform to the motor and it will feel real nice taking the battery in and out and keeping it snug when it's in the car. Really no need for the RT6 stop.
chevmaro is offline
Old 01-06-2015, 05:11 PM
  #11439
Trader Rating: 83 (100%+)
Just bought the gear diff. Does anybody know if you are supposed to use both gaskets or just one between the 2 halves?
dpcardoza is offline
Old 01-06-2015, 05:54 PM
  #11440
K_King's Avatar
Trader Rating: 47 (100%+)
K_King is offline
Old 01-06-2015, 05:57 PM
  #11441
aloksatoor's Avatar
Trader Rating: 43 (100%+)
I run super-stock so want a cooler motor. That's why I don't use foam and use the rt6 stop.
aloksatoor is offline
Old 01-06-2015, 06:35 PM
  #11442
do you have to have the newer chassis to use that stop? I won't mention any names but i know a person on here that made a pretty sic stop on a 3D printer.
CaseyD is offline
Old 01-06-2015, 07:06 PM
  #11443
E73
E73's Avatar
The brace is to prevent twisting under load from my understanding.
A flexible chassis seems to be one solution to gain traction with the RB6. I don't get it. A flexible chassis in racing motorcycles and automobiles is a bad thing because load is transferred to other parts of the vehicle. Any ideas?
E73 is offline
Old 01-06-2015, 07:40 PM
  #11444
K_King's Avatar
Too much flex is bad.
K_King is offline
Old 01-06-2015, 11:21 PM
  #11445
aloksatoor's Avatar
yes it's only on the lw and the newer stock chassis unfortunately
