Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 02-04-2014, 10:02 PM
  #9706
yodace's Avatar
Just got the new mm rf and rr hangers, was wondering if I run front d and rear d what would that do to the buggy?
yodace is offline
Old 02-04-2014, 10:15 PM
  #9707
Trader Rating: 90 (100%+)
More inside typically means more traction while outside is better for bumps/stability.
B-B was popular at first and it seems JPT's latest setup has D inside so the bushings are reversed. It's 4 screws.... see what works for your setup.
Kuya_Kimo is offline
Old 02-05-2014, 05:19 AM
  #9708
Originally Posted by aloksatoor
Yep you need an avid top shaft for it to work. Custom works I got but its sloppy. Tower hobbies sells it. Both need the avid top shaft.
http://www.exotekracing.com/b4-t4-sc...spur-gear-hub/
Use with Avid top shaft.
Jason.Dias is offline
Old 02-05-2014, 11:00 PM
  #9709
Originally Posted by Jason.Dias
Can you or someone please post pic of how to get exotek eliminator to work with avid topshaft. Because i have both pieces and cant get it to fit. The exotek shaft that sticks out with the oval cutout is far too wide and sloppy to sit stable on the avid. I may be missing something, so not sure. Many thanks
Glenn
glenng is offline
Old 02-06-2014, 10:21 AM
  #9710
E73
E73's Avatar
Glenn
I emailed Exotek to find out if they were designed for the Avid top shaft and here is what they said:
Hi Sir,
All our testing have been on the stock factory team equipment so no feedback on the Triad aftermarket sorry.
Could you let me know how it goes? If not compatible then you are welcome to send the parts back.
The good news is the RB6 spur mount should be in stock here in March.
Thanks for your support,
Mike Rydwell
EXOTEK
3830 Oceanic Dr
Oceanside, CA 92056 USA
E73 is offline
Old 02-06-2014, 10:31 AM
  #9711
aloksatoor's Avatar
Trader Rating: 43 (100%+)
I hope they offer it in black. Removed all the red from my rb6 recently!
aloksatoor is offline
Old 02-06-2014, 01:30 PM
  #9712
yodace's Avatar
Ne1 have a pic of which screws to remove, on the motor guard to ad more flex?
yodace is offline
Old 02-06-2014, 02:04 PM
  #9713
joecool's Avatar
Trader Rating: 22 (100%+)
They are the 2 3x8 flathead screws on the bottom of the chassis that hold down the center bulkhead.
joecool is offline
Old 02-06-2014, 03:18 PM
  #9714
yodace's Avatar
Dum question Would a #53 drill bit 1.51mm ,is that what they are using for the 1.5 holes
yodace is offline
Old 02-06-2014, 04:50 PM
  #9715
I use precision twist C50R10PM drill set and i bought a metric drill gage in case the smaller bits get mixed up by accident. I got it on amazon and the gage was from a local machine shop supply. And then i use general tools pin vise, the one w the big black handle
glenng is offline
Old 02-06-2014, 04:53 PM
  #9716
Hi Sir,
Mike Rydwell
EXOTEK
3830 Oceanic Dr
Sweet. Thanks for inquiring. I saw someone at the track w speedys eliminator (i think). And it looked sweet
glenng is offline
Old 02-06-2014, 05:08 PM
  #9717
Derry's Avatar
Trader Rating: 27 (100%+)
For you guys running mid motor and want to push the battery back further, I did this in about 15 min using the stock chassis and a piece of scrap metal. I did have to drill 2 counter sunk holes in the chassis for the placement of the front battery stop and 2 holes through the rear post dealies for the metal to go across the rear for the battery to rest against.
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-20140206_164245.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-20140206_164216.jpg
Derry is offline
Old 02-06-2014, 06:35 PM
  #9718
lore's Avatar
Hi Everybody,
I just install the Avid HD Long Rear Axle and nut, i have the feeling that the Kyosho Rim touch the bearing of the hub after tightened the wheel nut.
It looks not as free as with original Kyosho Axel and nut.
Anybody facing the same problem? Do i do something wrong? Any feedback will be highly appreciated.
Ciao,
lore is offline
Old 02-06-2014, 07:19 PM
  #9719
gelshocker's Avatar
Originally Posted by lore
Hi Everybody,
Ciao,
http://www.amainhobbies.com/product_...xle-Conversion
'In order to use the stock RB6 rear wheels, you will need drill them out to fit over the larger axle. Avid recommends a body reamer from the inside and it will do the job nicely. AVID HD Long Axles can only be used with AVID HD Rear Hex Adapters.'
gelshocker is offline
Old 02-06-2014, 07:35 PM
  #9720
yodace's Avatar
Cool i may have look in to that stuff. I found the drill bit, but I just wanted to make sure it was the right one. I normally just turn the dremel by hand with and leave it turned off.
yodace is offline
