Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-20-2013, 06:33 PM
  #4486
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Nice
Posvar is offline
Old 01-20-2013, 06:34 PM
  #4487
Trader Rating: 90 (100%+)
Originally Posted by desertracerdad
Had to change my paint scheme a bit, lighten it up as my eyes are not as good as they once were... The buggy & truck are much better than the guy behind the wheel of them
Nice scheme, love the jconcepts bodies on the rb6!
b121774 is offline
Old 01-20-2013, 11:04 PM
  #4488
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Trevor Williams
I wish more people would post pics of their rides, its always nice to see what others are doing.
I can post mine... complete with messy, ugly wiring and unpainted rb6 bulldog body (haven't decided on a new scheme yet).
DSCF2668 by silvalis, on Flickr
DSCF2669 by silvalis, on Flickr
silvalis is offline
Old 01-21-2013, 12:02 AM
  #4489
gelshocker's Avatar
Bulldog looks alright. BTW what tires are those and what surface do you run? Thanks,
gelshocker is offline
Old 01-21-2013, 12:13 AM
  #4490
savageboy69's Avatar
Trader Rating: 93 (100%+)
heres my rb6, still gotta tidy up reciever wires, and my new bodies were finally finished, no more one color wonder lol
savageboy69 is offline
Old 01-21-2013, 12:17 AM
  #4491
silvalis's Avatar
Yeah, better than the finisher
Although, I'd still prefer a regular non-cab forward body.
Those are worn red losi ifmar studs, silver losi ribs front. Loose outdoor hardpack. Run on wet, sticky dirt (with river clay mix I think). Gotta scrape through the top to hit the hardpack. Rarely gets clean enough to form bluegroove. Closely packed pins like calibres gunk up within a lap. After a race or two (or if the track is cleaner) I switch to ifmar pins, then to aka impacts. I run crowbars on the front in 4wd.
I've been putting these underneath my lipos lately. Serpent p/n 600479. foam pads. If I want it thicker or only want strips the xray xb4 strips are nice and thick.
silvalis is offline
Old 01-21-2013, 04:01 AM
  #4492
corky_rc's Avatar
corky_rc is offline
Old 01-21-2013, 04:49 AM
  #4493
Lonestar's Avatar
Trader Rating: 14 (100%+)
Here's Her Wiring Ugliness: mine - then again, try to fit stick + old-gen controller with MM without making a mess. Although, granted, it could have been better... one day, maybe, I can wire a car properly
Hey, at least, it fits, which wasn't granted from the start...
Lonestar is offline
Old 01-21-2013, 05:04 AM
  #4494
silvalis's Avatar
Does anyone else route their esc (or servo) wire in a channel underneath the battery?
silvalis is offline
Old 01-21-2013, 05:45 AM
  #4495
Trader Rating: 42 (100%+)
Originally Posted by eper
Check out my set up on petit rc it has tons of rear traction. Its under base setups and the name tom epting.
Tom, got your shock tool. works great. thanks.
noworries is offline
Old 01-21-2013, 07:58 AM
  #4496
Originally Posted by corky_rc
Who is making that battery strap in carbon?
Yzlvr is offline
Old 01-21-2013, 08:01 AM
  #4497
Cpt.America's Avatar
Trader Rating: 52 (100%+)
looks like diggity designs.
Cpt.America is offline
Old 01-21-2013, 08:05 AM
  #4498
Moderator
Posvar's Avatar
That is correct....I need to shorten my kyosho a little bit more and round it off and it will be perfect. I am making another set up with the k strap, gm post, and gm screws to sell.
It is so easy to do. I added a 2mm gm washer under each post per Brandon and it is perfect.
Posvar is offline
Old 01-21-2013, 08:06 AM
  #4499
Thanks..
Yzlvr is offline
Old 01-21-2013, 08:12 AM
  #4500
Pics?
Yzlvr is offline
