Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-14-2013, 06:36 PM
  #4291
Trader Rating: 29 (100%+)
Originally Posted by Dale.0
Will the same wheels that fit a B4 fit the RB6?
If you are using hexes yes. You will have to remove some depth from the hex area on the front wheels since the front hex on the rb6 is much thinner.
Yzlvr is offline
Old 01-14-2013, 07:23 PM
  #4292
What are the part numbers for the shock ends. Short, medium and long.
Turbo911 is offline
Old 01-14-2013, 08:20 PM
  #4293
Originally Posted by RodneyB
That is actually the part you are supposed to use for the rear motor config. That they sell it in a bag labeled mid motor is confusing. This part holds up well. The old thinner one will not usually last one run.
After closer reviewing manual you are totally correct, Thank You !
Dirt Works is offline
Old 01-14-2013, 08:23 PM
  #4294
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by lbckevin
I have a great kit then. I have none of these items and still run the plastic rear suspension holder. I run my car 2-3 a week and still have not broken anything.
Me as well. I have a first run kit and have yet to break a part.
Cpt.America is offline
Old 01-14-2013, 08:35 PM
  #4295
Trader Rating: 56 (100%+)
will TLR rims front/rear fit the RB6?
underway is offline
Old 01-14-2013, 08:40 PM
  #4296
silvalis's Avatar
Has anyone ever heard of a sensor cable with a right angled plug? I'm thinking something like those right angled SATA cables.
nope
Ditto.
silvalis is offline
Old 01-14-2013, 09:08 PM
  #4297
Here is my current setup if anybody is interested. Still a work in progress of course, so don't expect it to stay this way for long I update this exact PDF online with all my changes, so the setup will be different depending on what week you look at it. This is for a medium to medium high traction indoor clay track.
Brandon Collins RB6 Setup
Old 01-14-2013, 09:17 PM
  #4298
B00t13g's Avatar
Exotek users.
Are you using the factory metal bushings inside of the aluminum exotek rack?
B00t13g is offline
Old 01-14-2013, 09:19 PM
  #4299
toast.'s Avatar
Trader Rating: 14 (100%+)
Bookmarked - thank you!
toast. is offline
Old 01-14-2013, 09:56 PM
  #4300
silvalis's Avatar
Originally Posted by B00t13g
Exotek users.
I put mine on last night.
Yes.
Get some M4 0,1mm spacers too, as recommended. Eliminates wobble. Be sure to get as thin as possible, thicker will cause binding.
silvalis is offline
Old 01-14-2013, 10:07 PM
  #4301
B00t13g's Avatar
Yes.
Will do, thanks! I'm hoping they get here tomorrow or Wednesday!
B00t13g is offline
Old 01-14-2013, 10:41 PM
  #4302
MrHistory's Avatar
Originally Posted by K_King
Anyone try the 521-1 arms vs stock extensively?
Be sure to use a shorter ball end on your rear shocks with the RB5 arms. I first had the long ones on and the spring adjuster was backed out all the way. I use the short ball end. Have not tried the medium.
MrHistory is offline
Old 01-14-2013, 10:55 PM
  #4303
teeforb's Avatar
Trader Rating: 94 (100%+)
What's 521-1 arms?
teeforb is offline
Old 01-14-2013, 11:00 PM
  #4304
MrHistory's Avatar
RB5 Arms.
Old 01-14-2013, 11:03 PM
  #4305
teeforb's Avatar
Originally Posted by MrHistory
RB5 Arms.
Why use those?
teeforb is offline
