Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-24-2012, 04:41 AM
  #2791
Trader Rating: 56 (100%+)
Originally Posted by Jamison R
Lmao. I was gonna ask the same thing
Thats a good thing, LEARN from my pain....
underway is offline
Old 11-24-2012, 08:01 AM
  #2792
Trader Rating: 166 (100%+)
Originally Posted by mdowney
Sweet! Ordered everything.
Like everything except the graphite shock towers... Too many bad memories with my B44.
jpcopeland1 is offline
Old 11-24-2012, 09:19 AM
  #2793
K_King's Avatar
Trader Rating: 47 (100%+)
Only the mid motor config.
K_King is offline
Old 11-24-2012, 09:21 AM
  #2794
With a 17.5, what pinion should I go with using the stock spur gear? ...or should I not use that spur gear?? Thanks guys ...
ChadBlanton is offline
Old 11-24-2012, 09:50 AM
  #2795
pekow91's Avatar
Trader Rating: 45 (100%+)
I use a 69 spur (Kimbrough brand based on Captain's recommendation) and a 34 pinion with my 17.5 blinky. If you go the Kimbrough route make sure to pick up some Team Associted pads. The stock ones won't work with it.
pekow91 is offline
Old 11-24-2012, 11:22 AM
  #2796
t8rtot's Avatar
Trader Rating: 14 (94%+)
OR get the avid setup as the top shaft should be available soon
t8rtot is offline
Old 11-24-2012, 11:32 AM
  #2797
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I run a 17.5 revtech, and am geared here:
31/69 kimburough
maxed endbell timing
12.5 HT rotor
Cpt.America is offline
Old 11-24-2012, 12:25 PM
  #2798
fastestwon's Avatar
Trader Rating: 15 (94%+)
i figured out how to run the avid slipper unit with the kyosho top shaft . very easy to do
fastestwon is offline
Old 11-24-2012, 12:34 PM
  #2799
Trader Rating: 72 (100%+)
Default suggestions
Hello Folks,
I am new to the RB6, plan on running a tekin combo 7.5...
Any suggestions on the set up with the speedo and gearing? Thanks in advance...
Tmachine is offline
Old 11-24-2012, 12:35 PM
  #2800
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Do tell!!!???
Posvar is offline
Old 11-24-2012, 01:38 PM
  #2801
Avid worth it for mid motor?
mikeyscott is offline
Old 11-24-2012, 02:52 PM
  #2802
carbons2k's Avatar
Trader Rating: 21 (92%+)
Im running 72/30 and seems to be fast enough for me at the moment. After a 6 min run my motor barely temps at 100 degrees. Im sure I can go to a 33 but my car just feels amazing right now.
carbons2k is offline
Old 11-24-2012, 05:00 PM
  #2803
B00t13g's Avatar
Ran my rb6 for the first time in the third qualifier and finished 3rd in the A. As of now my b4.1 is faster, but they drive completely different.
B00t13g is offline
Old 11-25-2012, 01:18 AM
  #2804
All I can say is that Exotek ROCKS.
I placed My order of the options for My RB6 and I couldn't believe in My eyes.
I received them in 6 days in Greece via USPS and I was impressed with the quality.
I am making carbon fiber dive equipmentt for 6 years and I can say that I received a high quality ooptionals.
My only problem id that I can't wait to use the mid motor rear tower.
Coould somebody give Me some details about the difference between rear / mid motor usage becsuse thid is My first time with electric off road?
s.i.jerefos is offline
Old 11-25-2012, 05:40 AM
  #2805
Is there a difference in Tungsten carbide diff balls? Yokomo sells a set for less than half of the Kyosho ones.
underway is offline
