Kyosho Ultima RB6 & RB6.6 Car Thread
#3421
And FYI, #55s are actually 1.32. So 1.3s are actually a tiny bit smaller. And I have a pretty steady hand, but couldn't trust myself to drill all the holes identically in size and proximity on a set of blanks. The Gheas are machined and are flawless, which is why I went that way. The taper is also a neat feature.
#3422
Thanks guys for the shock piston suggestions. I'll have a look around and see what I can find.
#3424
It seems my RB6 spins out a little too easy when coming out of a tight corner and putting on the power. I'm running a shorty pack all the way forward - to the servo. I'm wondering if I should loosen or tighten the diff a little or move the battery back some to plant the rear end more. I don't want to give up much steering though ... Thanks
#3425
#3427
Try moving the pack back and/or going +4 caster inerts
#3429
Hey Chad, in my opinion it's not easy answering setup questions unless you're actually at the track with the person. For starters the obvious change to make is to move the battery back. I run mine all the way back but that's my track. A description of what kind of surface you are running on, tires you're running, what setup you have on the car now are all necessary to give you a decent answer. For now, with only the information you provided my answer is to move the battery back.
I apologize if I missed a post where you provided details.
#3430
Thanks for the help guys. I was too vague. Details are clay indoor track. Super soft rebars front and rear. Pink front gold rear springs. 0 castor inserts. All else is stock.
Now if a diff is too tight, both wheels will break loose together. If the diff is loose, the outside wheel will spin too easily??
#3432
Tires?
Tires are almost everything in offroad. Are the tires you are running what all the fast guys are running? Are the fronts giving you too much steering into a corner as well? You can spend all day trying another shim here 1 less there, more camber or less camber, different hubs, etc. If your tires are not hooked up you well never be as fast as someone that is.
On an indoor clay track I would think you would be running worn in gold barcodes or maybe blue, MC Suburbs, pink BK bars, or any of the bar type tires in indoor soft or clay compounds. I use super soft Rebars on outdoor dusty tracks. Not to say they wont work but just consider options. The front Rebars may be to aggressive as well.
Just my .02
#3434
some pics of the wiring hate yellow wheels and body isnt painted yet
#3435
