Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 12-15-2012, 10:22 PM
  #3406
Anyone running 4 hole #55 pistons in there shocks?
How are you doing this? Losi, ghea brand pistons? Or glueing a hole in the stock piston? Can't seem to find kyosho blanks in stock.
What is the effect between the 4 hole and standard piston? More pack?
If I was running 37.5/32.5wt losi oil on standard shocks would this be around 32.5/27.5wt on the 4 hole pistons?
Tom87 is offline
Old 12-16-2012, 03:38 AM
  #3407
Phil Trotta's Avatar
Default Limiters
Anyone running limiters. Lol. Nevermind .....
Phil Trotta is offline
Old 12-16-2012, 05:24 AM
  #3408
Trader Rating: 125 (100%+)
Pulled the trigger and ordered a RB6.
Is there a good starting setup for smooth indoor clay with med to high bite or iskit build setup decent? Running barcodes in gold.
kwiksi is offline
Old 12-16-2012, 07:09 AM
  #3409
vysoto's Avatar
Trader Rating: 15 (100%+)
Originally Posted by gelshocker
I still use the original UM131 with my RB5, just bend it outwards a little and it will hold. Check after each run and bend with your hands. Still using the original SP2 one.
The later thicker SP holder would bend just looking at it awkwardly. Unfortunately the RB6 only comes in this thickness and you need to stock up.
I was just wondering if this piece wold work in Carbon Fiber. or maybe a plastic like the one RPM uses for there products
vysoto is offline
Old 12-16-2012, 07:14 AM
  #3410
Trader Rating: 96 (100%+)
4x55's give more pack. You would probably want to drop the oil down when changing by about 2.5wt. The Losi BB pistons are a smaller diameter than Kyosho pistons so there will be more blow by around the outside. I've ran both Losi's and Kyosho's, the shock is smoother with the Kyosho because it's designed to all work together, the piston is the guide that keeps the shaft straight. When I made my K 4 holes I couldn't find blanks or get CA to stick to the piston so I plugged one hole with a tiny screw from a micro heli.
Eric Tomczyk is offline
Old 12-16-2012, 07:28 AM
  #3411
Weazsel's Avatar
Trader Rating: 70 (100%+)
LMFAO
I run .5 in the rear shocks for my local track... I might take them out though.
Weazsel is offline
Old 12-16-2012, 08:59 AM
  #3412
carcrusher46's Avatar
Trader Rating: 17 (100%+)
I've been running the Japan standard setup with the only modification being the rear hubs moved all the way back so the car will rotate a little better off power. That's it!
carcrusher46 is offline
Old 12-16-2012, 10:07 AM
  #3413
K_King's Avatar
Trader Rating: 47 (100%+)
I did some testing last night at our track and found a few more tweaks I liked on my car.
I also ran white springs a few time, but Golds are standard for me.
https://dl.dropbox.com/u/18166464/Ke...DRC%20Base.pdf
K_King is offline
Old 12-16-2012, 11:07 AM
  #3414
K_King's Avatar
Side note, anyone else have issues with Kyosho outdrives? Mine chipped, and I have the other side wearing as well. Anything I can do to make this stop? It has happened on all of my cars.
K_King is offline
Old 12-16-2012, 11:21 AM
  #3415
Cpt.America's Avatar
Trader Rating: 52 (100%+)
They are wear items... as are the swing shafts.
Cpt.America is offline
Old 12-16-2012, 11:23 AM
  #3416
Trader Rating: 166 (100%+)
If you need spares I have a pantload on the for sale threads cheap. Spares of spares I don't need cause the car is that bullet proof.
jpcopeland1 is offline
Old 12-16-2012, 11:24 AM
  #3417
It would be close, but not exact. I run Losi pistons, cheap, and do the job awfully well.
Old 12-16-2012, 11:41 AM
  #3418
Iv been running the losi 55s for the last couple weeks, but just changed over to the Ghea 1.3s last night, and found a noticeable improvement. Car soaked up the bumps just a tad better... shocks are smoother. The losi's don't fit as well, in both the shock body, and inbetween the two eclips on the shock shaft. They are pricy... but I think worth the money if looking for a 4 hole 1.3.
Old 12-16-2012, 11:53 AM
  #3419
K_King's Avatar
I run blank Kyosho drilled to #55 (1.3mm) and they are noticeably better than Losi 55s, which arent really 55s. Closer to 55.75s or something.
K_King is offline
Old 12-16-2012, 12:07 PM
  #3420
And FYI, #55s are actually 1.32. So 1.3s are actually a tiny bit smaller. And I have a pretty steady hand, but couldn't trust myself to drill all the holes identically in size and proximity on a set of blanks. The Gheas are machined and are flawless, which is why I went that way. The taper is also a neat feature.
