Kyosho Ultima RB6 & RB6.6 Car Thread
#3318
I flipped the rack back to stock and often put 1 or 2mm of spacers to increase the turn in and aggressiveness, as I find on tight and twisty tracks I want the back end to slide a little to help the car turn and square up quicker for the exit.
#3319
30/0 is better for high speed steering when the car is really rolling... it will tame out your slower speed / infield steering, where the car isn't rolling much. 25/0 is better for low speed steering.
I found the infield steering to be a tad too aggressive for me, so I currently run 30/0. (but im not necessarily stuck there, still a work in progress)
There is another affect the car will see by going to 30/0, and that is more off-power steering, due to the increased front kick-up/pro-dive.
#3323
Yep...I don't have much of a choice right now because I run the same batts in all my cars. Full size stick batts. I checked out your set-up. No doubt, better for lower cg. It was just a surprise for me since Kyosho advertised full size stick pack w/MM combo, yet the batt can slide all over the place. I could put some foam back there, but it would be pressing against the motor! Thanks for the pic.
#3325
My cars only been to the track 3 times total, so about 10 packs through it. I was doing some matience on my car and noticed that where tranny sits on car my chassis is denting in kind of a sqaure looking shape. Is this a known issue? Is Kyosho Warrenting the chassis? If so how do I contact them?
#3326
#3327
[QUOTE=Mxer59;11548894]My cars only been to the track 3 times total, so about 10 packs through it. I was doing some matience on my car and noticed that where tranny sits on car my chassis is denting in kind of a sqaure looking shape. Is this a known issue? Is Kyosho Warrenting the chassis? If so how do I contact them?[/QUOTE
hers a link with a number.. i have heard they are replacing them for people.
http://www.kyoshoamerica.com/crm.asp?action=contactus
#3328
I decided to go back to the ball diff so I started to tear down the transmission yesterday. My aluminum suspension blocks also came in the mail so I decided to install that as well. I took out the composite blocks and realized I made a HUGE rookie build mistake. I had the wide inner block and the NARROW outer block installed!! I think my 2nd driving experience with my RB6 will be much improved.
#3329
#3330
[QUOTE=eper;11549759]
last time i talked with kyosho usa on this issue . their stand is only extreme cases will they do anything .first you will need to call then you would need to take pictures send them to them if they feel it is bad enough they will have you send in your chassis to them . after that they will make a determination as what to do . i know of only one that they replaced . mine has a little dent i made a insert that goes under the transmission problem solved .
