TLR 22SCT Thread (Check First Page for FAQ & INFO)
What is the best gearing for a 17.5 for a small, technical indoor dirt track? Thanks.
The track is hard packed black dirt.
Diff is usually a barking noise. slipper a bit more of a squeal i would say. squeak could be a bearing as well
I couldn't wait for the 2.0 to come out in Oct, so I bought a used 22SCT and converted it to mid-motor. I got a killer deal with a Tekin RS ESC, so it was worth it. The previous owner said he had a lot of the 2.0 upgrades on the truck already. Being new to this platform, I can't tell the difference between the original vs. the 2.0 parts.
I've already ordered the Exotek steering rack because the slider that's in the truck now has a ton of slop. I also rebuilt the shocks using the machined cartridge components and 2.0 o-rings.
I plan on ordering the 2.0 spindles/rear hubs and caster blocks, but before I do, is there a way to confirm which version is already on my truck? Are there visual cues that can tell me one way or the other? Obviously I don't want to order the 2.0 parts if they are actually already on there.
Thank you very much Jon, that is exactly what I was looking for . I'll check it out when I get home. Is there any way to distinguish the 1.0 vs. 2.0 rear hubs?
There isn't really a benefit to switching them out unless you need more clearance based on your camber link location.
I went the Exotek route on the SCT and couldn't be happier with the change. much more precise and consistent steering. Not cheap though as i had to get the Exotek servo mounts as well. Im using a Spektrum S6040 and its length from the mount tab to shaft head is above 14.5mm. This is the maximum height or the horn wont clear. If you go the Exo route, just make sure you read the docs on the Exo site (before you buy...) and measure your servo height. Its well explained.
CRAP! I wish I would have seen this post before I ground down a perfectly good aluminum servo horn attached to a Savox Servo in order to get it to fit under the front bulkhead arms
the exotek steering rack ver2 should work with this servo, Savox SC 1251MG Low Profile
I just installed it and it is friggin' sweet :-D very happy with it
Hello,
I want to know more about Team Losi Racing 22 SCT 2WD.
1. Is this car easy to drive for asphalt on road racing ? In my country, on-road short course racing is becoming more popular. Racers usually piloting 4wd team losi scte and tekno racing 4wd. I want to use 22 SCT 2WD for simplicity reason. Am I going to be disappointed chosing 2WD truck ?
2. As part of on-road SC racing regulations in here ..... Racers are required to use 1/8 On Road GT Tires. Usually they use Sweep Racing tires. Therefore , 17mm Hex Adapter must be use for aforementioned tires. Is this fit ? MIP 17mm Hex Adapter Kit, Traxxas Slash 2wd #10114.
3. Do u have any suspension setup suggestions for asphalt racing ? Should I use middle or rear motor mount location ? I prefer to have stable rear end rather than fish tailing rear end.
Thank you for enlightening me.
Hello,
2. 17mm - Can't help on that one. There are quite a few different 17mm adapters systems out there. Not sure which ones work and work best.
3. Setup - For on road, there should be no question, mid motor. As far as setups go, if there are no jumps, stiffen it and lower it as much as possible, try it, soften up as needed to get traction. If there are jumps, then look at at setups from some of the sugar watered off road races as a starting point.
