TLR 22SCT Thread (Check First Page for FAQ & INFO)
#8191
Is it just me or is the rear sway bar out of stock like everywhere?
#8192
Thanks for the report. Good tips in there! I'm 3/4 of the way through my conversion. One question....why are you using the low-mount ball stud from the 2.0 on the steering kit? Mine seems to work fine w the hardware from my SCT kit. They appeared a little long, but i just went slow and neither had an issue when I screwed them in.
I did use the standard 6mm ballstud since I was waiting on the low mount. I sourced one locally before I actually drove the car so I ended up using it. They are 6mm as well, I believe. No issues fitting either.
#8195
I also upgraded my steering rack, changed shocks to the new machined parts and x rings. I also swamped the spacers for the aluminum ones and the hinge pins for the new 2.0 ones. I really like how the pins that hold the rear hubs in place use bolts instead of E clips. Ireally hate those little things!
I'll report back once I drive it, but the car feels nice and tight and I'm not experiencing anything that would need a dremel to fix.
#8196
Ideally you'll probably want to adjust the rear so that you have a balanced vehicle, though I don't know if you actually need to buy anything new to do that.
That said, the new front arms that the caster blocks fit into have a different opening size. I noticed last night that you don't use the spacer when assembling, and perhaps you can dremel out the arm to make it fit (might lose a little durability).
#8198
I noticed some setup sheets are using buggy rear springs,whats the difference between them and the truck springs
#8200
If I don't like it, first tweak will be to un-shim the tranny.
#8202
Can someone tell me what size drill bit or reamer I would need for where the pins go in the castor blocks?
#8203
It dosen't seem to me that the SCT has the same issues as the buggy did. Why throw those 22 2.0 parts on there now? Why not wait till there's a truly dialed part set offered? The slider I get - it appears to be better and it would be nice to play with the bump steer but the rest - calm down!
#8204
#8205
Because it's fun to tinker with stuff and see what the end result would be. I had the same exact thoughts as you, but then I saw TLR marked on the packages that these parts fit the SCT also. Mine went right on with zero mods needed. If I don't like the way the truck drives, I'll switch em back and have some extra parts for my 2.0 buggy.
