TLR 22SCT Thread (Check First Page for FAQ & INFO)
#7501
R/C Tech Elite Member
New to SCT what tire for loose outdoor
I THINK I'm Going to get a set of Holeshots M4.... front and rear.
Does this Truck turn well? should I get M3 for front> or some other Grouve tire. What combo do you guys use.? Picking your brain.... Track mostly loose Big outdoor . Tazer?
#7502
Thanks for the input sapperc.. i have 0 degree castor blocks now and i plan on changing out tha steering rack too. this truck has a secret "Flair" button on it and i plan to find it. and when i do.....its gona put the Woooo in somebodys WOOOOOO!!!!
#7503
if your familiar with the 22 platform, you shouldn't need to ask if it has enough steering.
on my truck, I initially set the steering travel on my DX3C to 143% to get the spindles to bottom out on the castor blocks. I have since gone to around 125 to 130%; it was toooo much!, and I think if you teach yourself to use less of the steering, you can carry more speed through a corner, and maybe be a little smoother driver
has anybody had the chance to test the 2mm trail spindles on their 22SCT?
is the 2mm trail more aggressive right? twitchy? More Steering??
#7504
big track?
try caspers setup. works really well.
#7505
I broke a 4mm trailing spindle and had to put on a spare set of 2mm trailing so I could race the next day. The difference was massive. As Casper said, their is so much more turn in. It took me all day to get used to it, and in the end it made it a lot harder to drive.
#7509
I have run M3 soft all around, works really well for me, but i am running 17.5 blinky
and for getting more life out the tires, soft is fine for me!
good to hear, my local hobby shop has a few sets of 2mm trail. I am going to give them a shot, see what I think of them.
#7512
I think they leave a little to be desired for sure. I also don't like how they mixed mid-motor steps in the middle of everything else. But.. once you put the kit together, you'll realize that it's actually pretty simple. I've taken my apart a number of times with no instructions since.
#7513
#7514
Tires
Last year I ran M3 Tazer all around and like it. This year I have tried M4s in the rear and M3s in frt and am having some sucess with it. Have notice the M4s work a little better on the clay track I travel to.
#7515
Anyone running the AE VTS slipper? Mods required?
