TLR 22SCT Thread (Check First Page for FAQ & INFO)
#7321
I am slowly realizing the importance of the diff in a 2wd car as you guys continuously talk about it. I have spoken to you before on when to rebuild the diff Casper and you said that you don't time it and that you only redo it when it needs to be rebuilt. How do you know when it needs to be rebuilt? Is there a certain feel or a certain sound? Does the truck start to act differently?
#7322
I know that you are popular in R/C Casper and that you are probably very busy. But if you could I am sure rookies like myself would appreciate if you could make a video that demonstrates the best way to build/rebuild a differential on a 2wd so that we could learn the best way to do it. I am just throwing it out there. I am reading a lot that the diff can be the make it or break it difference of a 2wd rc car so it would be great us rookies could learn the proper ways to make your diff the best there is. Thank You
#7324
R/C Tech Elite Member
#7325
Just want to give a Big thanks to everyone in the thread that helps answer questions. It's a nice community here. Casper goes above and beyond in these forums.
#7327
In digging through my stuff I found a sealed diff from my xxxsct will that fit in the 22 trans.
#7328
Nope
#7329
http://www.losi.com/Products/Feature...rodId=LOSA2954
#7330
Yeah they are like the XXX thrust bearings they sell with the grooved washers and caged ball but the balls are ceramic (not sure if Bfast sells them this way?) and they are the right size for the TLR or AE diffs.
#7331
+1000 For a dad who had no experience in rc my pit skills have had a hard time keeping up with my son's driving skills To all the TLR guys and all that contribute Thanks
#7332
I got an early sneak preview of the caged thrust bearing from Casper and have been running it since January - 1-2 times a week and have rebuilt my ball diff 4-5 times. The thrust bearing Casper sells holds up great. This is not something you need to replace every rebuild and It has withstood building the diff super-tight multiple times. Has not flatted or worn out the rings. Works good.
#7333
Does anyone have experience w muchmore diff grease? My lhs won't have tlr in stock before next race.
#7335
Another thing about the diffs. I know that the manual calls for you to use black grease on the thrust bearing and clear diff lube on the main diff balls. Do you guys recommend anything different for the thrust bearings and diff balls?
