TLR 22SCT Thread (Check First Page for FAQ & INFO)
#5881
#5882
#5883
If you have the strap go under the battery at all it will not hold it down in place properly. Velcro straps work great. There are carbon options from companies like JC and others.
#5884
how are you useing the velcro straps? The entire strap should be above the battery. Look at figure E-9 in the manual.
will give the correct way a try
#5888
Learned my lesson the hard way....ran batt. between the straps, and it moved...crashed into my receiver & bent the plugs....ran the straps above the batt. and absolutely no movement.
#5889
If you have all your pads in there it shouldn't move. I run my batteries between the straps, always have.
#5892
Try running Barcodes rear. I ran pressure points to try them. My findings were they can be good but more as a front tire than a rear. But there's a small window in conditions that they really accell which is damp clay. Too wet and they slide because they're not deep enough, too dry and they dont bite. That's just my observations from using them. I went from PP's at all 4 corners to BC's rear and PP's up front, finally was happiest with BC's at all 4 corners.
#5895
Remember, new tires always take a few packs to break in so try running them all morning/day. Once you have about 4 or 5 packs on them they should hopefully start to get really good depending on how the wear is at your home track. Good luck and let us know how it works out for you.
