TLR 22SCT Thread (Check First Page for FAQ & INFO)
#3212
#3213
If you get new stuff and you are just playin it may not really be necessary.
I race a bunch and run with older stuff, might even be famous for it!
My "go to" speed controls are Novak GTB and I have a few different motors, all were good deals and the right price. If you take basic care of these they seem to last forever.
Of course it's a different story when I'm trying to be competitive in a 17.5 no boost class where a fresh battery and motor geared on the edge can make a very noticeable difference cuz this class is a "just barely enough power" class.
If you're talkin modified motors you can make more than enough power with any of em. (sportsman talkin here, pro or expert different story)
#3214
i got a novak gtb sport man esc in a sc 10 4x4 with 4.5 trun 550
#3216
#3218
novak it is thanks. do i need tires lol jk
#3219
If running rear motor, its just the shims under the rear arms front pivot mount. If running mid like you are its the shims and the matching blocks that go in the pivot mount. Your SCT came with the LRC mounts. Make sure if you order the full kit you get the LRC, unless you want the HRC for some reason, but then youll have to get the HRC toe blocks to match.
Also if you raise the tranny, you put the same spacers as the rear motor plus you have to put an extra 1mm spacer under the front of the tranny on top of the front pivot block
#3221
#3222
#3223
are the new pre cut high flow losi body out now .
#3224
Yes they've been out for quite some time. Available at many online retailers or you can ask your LHS to order you one.
Well, got home from work tonight and sitting at my door was a nice box from Horizon Hobbies. Opened up the box and there they were, the new ballcups!!! I have to say, they might have gone just a little overboard with the packaging lol a small envelope would've been fine In seriousness though, this is EXCELLENT customer service that we've gotten from TLR. They could have just sent the ones for the steering rack, but nope, they sent 12 ball cups total. That's great customer service. Thank you TLR/Losi/Horizon, you guys are all a class act! Here's some iphone pix of them.
#3225
Trader Rating: 171 (100%+)
I got the new ball cups from Horizon on Monday ran them tonight and all I can say is WOW. I took so real good hits and they didn't pop off.. Nice job TLR & Horizon.. Quick question what dose putting the 1mm shims under the tranny do. Thanks
